My 06 has been a good truck - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Diesel Forums!
Dodge Caliber
Place your Ad Here!
Old 04-08-2011, 11:06 PM
magazine magazine is offline
magazine is on a distinguished road
Default My 06 has been a good truck
I bought my 2006 new in June of 2007 and put 32k miles a year on it. I've got over 125k miles now. I had a front wheel bearing go bad and it wasnt covered even though there was a recall on the front wheel bearing due to not applying enough grease on the 06's. I had the transmission flushed after 100k and it didnt have any buildup at all, fluid was still clear. I've changed the oil every 5k miles myself, never took it anywhere to have it done. I tend to drive a truck easy although I pull a tandem axle trailer with a hot pressure washer and tanks, probably 5000 lb. trailer. It does tick and knock some when I first start it up in the morning but after 15-30 seconds, it stops. Driver seat is worn pretty good on the outside edge and I'd love to find a new oem bottom seat cover and foam. Overall, its been a great truck no real problems whatsoever. I have no idea how many more miles I can get out of it. The only maintenance I've done is oil changes and air filters, a trans flush, front end alignments, and rear differential oil change once.
Anyone know of any other maintenance I might have done to get another 125k out of her?
2006 Dodge Ram 4x4 Reg. Cab SLT
2.5" Rough Country Lift Kit
Old 04-09-2011, 12:09 AM
Plugs & wires would be one.
Replace EGR valve
Clean throttle body
Lube body mounts
Lube all wheel bearings.
As long as you keep servicing those boxes you have quite a few miles left. What you will start experiencing is wear parts and replacement items starting to mount up a bit on you. But it sounds like you have done a good job of keeping up with the major services.
I would not go beyond 30k miles on differential services or 50K miles for the trans service. I suggest you shorten your intervals there.
Good luck!
newbie here looking for good mods for my truck cmgarmy Newbie Checkin! 11 10-18-2010 10:29 AM
Dirt Builds Up in the Bed of My Truck Rocky Harbour 2010 Dodge Ram Forum 4 05-27-2010 12:23 PM
Getting ready to put truck up for sale............. LadyRam 5.7L (345 cu in) HEMI V8 Specific Topics 34 02-01-2010 05:54 PM
What would you do? smarthead2006 2009 Dodge Ram Forum 14 01-12-2010 04:18 PM
Need opinions on what will make my truck look good JustLive LD RAM - General Discussion 9 09-27-2009 12:19 PM
