Old 04-09-2011, 01:06 PM
belle belle is offline
Vehicle: 2011 Dodge Ram Laramie
Trim Level: laramie
Color: rugged brown two tone
belle is on a distinguished road
Default Leveling kit and tires, BUT?
I had a Ready Lift 2.5 inch leveling kit and four 275/65/20 Hankook Dynapros installed with alignment. The truck looks great, BUT there seems to be a slight roughness to the ride now. Could it be the tires because they are aggressive and larger than stock, or the wheels/tires aren't balanced correctly, or the alignment is off? Should I have the tires rebalanced and a new alignment done, or is the difference I feel to be expected after the changes that I've made?
Old 04-09-2011, 01:24 PM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
Can you define roughness? I have several things coming to mind but need help to understand better. Is there a vibration, at what speed?
Old 04-09-2011, 01:27 PM
Sometimes a leveling kit will roughen the ride some. Add the knobby more aggressive tires and it will feel stiffer.
Is the truck pulling in one direction or another?
Old 04-09-2011, 01:40 PM
nYmPhMoBiLe08's Avatar
nYmPhMoBiLe08 nYmPhMoBiLe08 is offline
Vehicle: 2008 Dodge Ram
Color: Metallic Gray
Rep:75
nYmPhMoBiLe08 will become famous soon enough
Tires could be over inflated, leveling spacer will stiffin up the front suspension, if you went from a smaller wheel to larger then roughness will increase too...
~Landon~
Current MODS: | Bilstein 5100's (Front) | Monroe Coil Overs (Rear) | Tow Mirrors | Husky Tool Box | Plasti-Dipped Badges/Gas Cap | 295/70/17" Nitto Trail Grapplers | 17X9" Fuel Boost Wheels | 3" DMH Cutout | RT Stripes \\ | WeatherTech Floor Liners |
Old 04-09-2011, 01:57 PM
Trim Level: laramie
There is no pull in either direction. It's more like a feel of a tremor through the steering wheel as I accelerate. That's why I thought it may be a balancing issue. The wheels are the stock 20s. Tires are 65s, in place of the stock 60s.
Old 04-09-2011, 02:05 PM
RedRam10's Avatar
Rep:743
Sounds normal, what tires did you go with? Were they much more agressivly treaded than the stock GoodYears?
Old 04-09-2011, 04:46 PM
BiggBerger BiggBerger is offline
Rep:43
BiggBerger is on a distinguished road
Ive heard that that slight tremor is normal with a 2.5 kit but not so much with a 2" kit.
Old 04-10-2011, 01:36 AM
Rammin's Avatar
Rammin Rammin is offline
Vehicle: '03 Dodge Ram 1500 2wd
Rep:44
Rammin is on a distinguished road
Assuming your Dynapros are MT's that's probably why. Anytime I've put on new mud terrains they always feel different. Give them a couple thousand miles and they should get better too.
Old 04-10-2011, 11:21 AM
dave3.4 dave3.4 is offline
dave3.4 is on a distinguished road
got any pictures of it? sounds about what I want to do to my truck.thanks
