Old 04-10-2011, 03:08 AM
Mopartruckin Mopartruckin is offline
Vehicle: 2001 Dodge Ram 1500
Trim Level: Sport Off-Road
Mopartruckin is on a distinguished road
Default Engine surges, idles high
I have a 2001 1500 with 162k on it and I have noticed that from time to time the engine when at idle, surges to about 1200rpm, back down and then up again. It does it even when in gear.Engine light hasn't come on, could the ECM be throwing a code anyway? Need help
Old 04-10-2011, 11:03 AM
sdram03's Avatar
sdram03 sdram03 is offline
Vehicle: 2014 RAM 3500 Big Horn
Color: Maximum Steel
Rep:52
sdram03 will become famous soon enough
check your IAC and make sure it's working properly and doesn't have any carbon buildup. or maybe the TB just needs a good cleaning. you might have a small vacuum leak that the computer is trying to compensate for. i usually spray a bit of Carb cleaner around any gaskets (like TB, intake) and vacuum lines to see if the engine runs different. if it does, something has a hole that needs fixing.
good luck!
if you're gonna go, go with a smile!
2014 RAM 3500 Big Horn CTD CC 4wd in Max Steel
Old 04-25-2011, 08:22 PM
I tried cleaning the IAC and it solved the problem but now its back again. I wonder if the IAC is worn out and just needs replacing?
Old 04-30-2011, 04:51 AM
RAMING IT's Avatar
RAMING IT RAMING IT is offline
Vehicle: 2002 DODGE RAM
Trim Level: QC SLT 2WD
Color: Almond Pearl, Blacked Out
Rep:65
RAMING IT will become famous soon enough
I say replace it. Have you check all your vaccum lines, clean you tb with seafoam make sure you pull your pcv valve and clean that up aswell.
Heavy A$$ truck w/ ported stock heads, intake / heads gasket matched, keg mod, iat mod, cks mod, 2 tone vinyl wrap, blacked out trim, (pcm junkyard mod)
Old 04-30-2011, 08:18 PM
Vacccum lines check, seafoamed the engine/TB, and all seems well for now. Went ahead and bought the IAC but will wait to install and see if the seafoam worked. Thanks for the advice
Old 04-30-2011, 10:22 PM
RAMING IT's Avatar
Rep:65
Cool
Thats great. Hope it works keep us posted if any future findings.
Old 05-03-2011, 08:01 PM
TonyRomano TonyRomano is offline
TonyRomano is on a distinguished road
having a similar problem when at idle, feels like vehicle is shaking every few seconds. have checked vaccuum lines and haven't found a leak, what do you mean by seafoaming?
Old 05-04-2011, 01:39 AM
RAMING IT's Avatar
Rep:65
SEA FOAM (white can with red letters) Its a great liquid cleaning product that cleans your fuel lines when poured into fuel tank, oil sludge when poured into crank, valves, tb and manifoldwhen poured into air intake system. When poured through you throttle body with truck running engine sucks it in, let it sit for 10 min while it breaks all the gunk off then it shoots it out the tailpipe when you turn your ram on at high idle. That's realy it in a nutshell.
You'll find the liquid at your auto parts store,
Old 05-04-2011, 05:24 PM
Talking
thanks for the insight
Switching to Synthetic in High Milage engine Y or N GASHAWG Dodge Ram Forum Polls! 14 09-02-2014 06:28 AM
Octane Rating (good info) Jay Fuel System 21 06-08-2011 02:02 AM
Regular gas in a 2010 ram with a hemi? Ray Dodge Ram MPG Zone 31 01-21-2010 12:04 AM
What kind of gas do you use?????? bransonshemi Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 61 12-08-2009 10:38 PM
Octane Rating (good info) Jay Dodge Ram General Discussion 3 03-27-2009 09:30 AM
