Old 04-11-2011, 01:14 AM
srt93 srt93 is offline
Vehicle: 2006 dodge ram 1500 4x4
Trim Level: laramie
Rep:55
srt93 will become famous soon enough
Default bilstein shocks
hey guys i was wondering if you can use a coil spacer leveling kit and bilstein shocks for a total 3 or so inches of lift in the front end of a truck? if im not mistaken bilstein stocks are the adjustable ride height ones.
Thanks
Old 04-11-2011, 01:19 AM
sk8noregon's Avatar
sk8noregon sk8noregon is offline
Vehicle: 2008 Dodge Ram
Rep:637
sk8noregon is a name known to allsk8noregon is a name known to allsk8noregon is a name known to allsk8noregon is a name known to allsk8noregon is a name known to allsk8noregon is a name known to all
I believe you can, I think ScatPak07 did a 6" suspension lift and used Bilsteins also if not mistaken ? Although I am not certain if it is good to go more than 2.5" in the front without getting new A-Arms and such because of the change in geometry at that height. Maybe he will chime in here as he will most certainly see this thread !
"Rocky and Bullwinkle"
Join the "Mineral Gray Metallic Ramz Group" here !
Old 04-11-2011, 01:24 AM
Trim Level: laramie
Rep:55
i really hope so... i want just an extra inch to two inches in the front so i can put 1.5 inch or 2 inch blocks in the back and it will still sit level
Old 04-11-2011, 01:26 AM
FormerGorilla's Avatar
FormerGorilla FormerGorilla is offline
Vehicle: 2010 Dodge Ram 4x4 Crew
Rep:147
FormerGorilla will become famous soon enoughFormerGorilla will become famous soon enough
Only the 5100 series bilsteins are adjustable to my knowledge. And I wouldn't recommend both. That would put a LOT of strain on your ball joints and your front axles. The 'steins adjust up to 2.8" for the 3rd gens I believe, so your almost there if you adjust to the highest setting. If you go too much higher your also risking vibration and wobble as well. How about 5100's and then a body lift?
MODS LIST! -- 20% Tint, Curt Rec. Hitch, Slimline Toolbox, Huskyliner mats, Huskyliner Mud guards, 18" Gear Wheels, 33" Hankook ATM Tires, Bilstein 5100's at 1.4", Ported Foxbox w/2 10" Polk Subs & JL 500W Amp, Mufflex 24" Exhaust, Tow Hooks, Dominator II Step Bars, GatorHyde Spray-In Bedliner
Old 04-11-2011, 01:27 AM
Vehicle: 2005 Dodge Ram 2500
Color: Mineral Gray
Rep:177
I remember seeing scat mention a lift you could use with bilstiens (6" lift plus 2.8" bilstiens i think it was although I cant remember the name) to get more height but I dont believe you can use spacers with bilstien adjustables
Old 04-11-2011, 01:29 AM
Rep:147
You might be able to use a lift with them because a lift will correct your CV shaft angles, but adding a spacer with the 'steins will just increase the angle.
Old 04-11-2011, 01:33 AM
Trim Level: laramie
Rep:55
okay thanks guys, i might just stick to the 2 inch leveling kit for the time being since i do not know how long i will have the truck for. Just thought id see if i could get a little more height for cheap. Thinking about getting rid of the hemi for a cummins, but thanks!
Old 04-12-2011, 02:13 PM
BigHorn 4 Life's Avatar
Color: Briliant Black
Rep:463
If you have a 2" leveling kit now and you want to add the Bilstein 5100's? So your wanting to add 1 -2" more lift in the front without a lift kit? Ya your asking for trouble bro if you do this.Your cv's would be too far at an angle and your balljoints would have way too much stain on them as stated above.If you want to go higher go with a body lift or do a suspension lift.
I have a 6" BDS kit with the Bilsteins on the front set at 2.8". It works like this.Not with just a leveling kit. You can take the spacers out and buy the 5100's and set them to max settings but you still might get some vibration.
Old 04-12-2011, 09:26 PM
ScatPak07's Avatar
Rep:970
Ya you dont want to go higher then a leveling kit without a lift kit. The lift kits will do it properly and if you cheap out then your going to cost yourself more in repairs. The lift kits come with a subframe which lowers the front diff which will correct all of the geometry in the front end of the truck. This will give you a safe and sturdy ride. If you have a lift kit then you can use the 5100s because the lift kit brings everything to stock. So this would be like adding a leveling kit all over again to the truck.
Bilstein 5100 shocks problems... mmalloy 2009 Dodge Ram Forum 12 04-23-2011 12:26 PM
Bilstein 5100 Shocks MAXX25 2010 Dodge Ram Forum 63 03-30-2011 01:40 PM
Bilstein 5100 shocks w/strut extenstions? Gergas Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 2 01-04-2011 09:24 PM
Need Help with Shocks!!! jpaul51 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 6 12-05-2010 12:40 AM
bilstein shocks? husky Dodge Ram 4x4 - Offroad Discussion 5 11-28-2010 09:55 PM
