Old 04-11-2011, 10:35 AM
brandong brandong is offline
Vehicle: 2006 Dodge Ram Big Horn
brandong is on a distinguished road
Question HID 35W 6000k issue
I've searched all over on here and I've found some people having some similar problems but not like mine. I installed some 6000k HIDs and I have the flickering issue as well. But with the ignition off or in the on position with the truck not running the low's and high's work fine but as soon as I start the truck the lows will flicker about 2-3 times then go out but the Highs will work fine. If I turn the lights off for a few seconds then back on then the lows will work again IF the truck is not running. Can't figure it out. I read a thread about a 4700uf cap from radio shack but I'm curious if that would fix my issue.
Bought HID's from DDM tuning and had no problems at all in my GTO with their product.
TIA-
BrandonG
Old 04-11-2011, 05:40 PM
PARamRod PARamRod is offline
Vehicle: 2002 Ram 1500 SLT
Color: Black over Silver
PARamRod is on a distinguished road
I bought HID's from DDM as well. I have a 2002 ram and I had to buy resistors to dummy out the computer so it think it sees the old lights. I was haveing the same problem as u. That should fix the problem
Old 04-11-2011, 06:46 PM
col's Avatar
col col is offline
Vehicle: 2012 Ram 3500 CCSB
Trim Level: Laramie Longhorn
Color: Black & Gold
Rep:92
col will become famous soon enough
I have the exact same problem with my Low's on my 09. Just not got round to fixing them yet. I'm just running the fog's for now. Plenty of light just with these.I will probebly try the same Cap but can't find one here in Calgary.Good luck man & let us know how you go on.
2012 3500 Cummins Laramie Longhorn CCSB | 68 RFE | Black over Gold | RaceMe Pro Tuner | Flo pro 4" Stainless Steel Turbo Back Straight Exhaust | 5'' S/S Tip
Old 04-11-2011, 08:00 PM
PARamRod...What resistor did you get and where did you get it at? Is it something that can be bought at a radio shack or purchased online?
Old 04-12-2011, 08:39 PM
I got them off of ebay.. http://cgi.ebay.com/ebaymotors/50W-6...#ht_5379wt_919
They come 2 to a pack and u"ll need 2 packs total... if u need help with the wiring let me know..
Old 04-13-2011, 01:27 AM
flip203 flip203 is offline
Vehicle: 2004.5 Ram 2500
Trim Level: SLT 4X4
Color: Blue
Engine: 2004-2004 359ci (5.9L) Cummins ISB 600 24-Valve Diesel I6 325hp 600lb/ft (6-Speed Manual)
flip203 is on a distinguished road
I bought my caps from radio shack and they work fine. Without the caps they would not work if the truck was running. Do pay attention to the direction marked on the cap. The arrows will point to the ground wire. I'm also a member of a diesel forum and most of those guys recommend a 20w resistor for each 35w ballast to fool the truck into believing it is using 55w draw. If you are running 50w ballast just get a 10w resisitor. They also recommend if you have aftermarket projectors with a separate high beam to make a relay so that when you switch from low to high the lows stay on preventing them from having to warm up again and leaving you with a low light situation fo a few seconds.
Bought new HID bulbs but have problems str8hemi Custom Dodge Ram Interior and Exterior Lighting 9 09-28-2011 03:39 PM
HID issue that needs fixing FAST please Quiet Lunatic 2010 Dodge Ram Forum 33 04-26-2011 02:34 PM
HID issue that needs fixing FAST please Quiet Lunatic Dodge Ram General Discussion 3 03-16-2011 02:20 PM
6000k HID Install!! 09Ram RT Custom Dodge Ram Interior and Exterior Lighting 15 02-12-2011 02:07 PM
Vibration Issue WickedSix 5.7L V8 Specific Topics 5 01-13-2011 12:30 AM
