ScanGaugeII in a Ram Van - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > Dodge Ram Special Edition Models > Dodge Ram Vans
Dodge Ram Vans For discussion of Dodge Ram Vans. Please use our existing technical areas for driveline discussion, etc.
Old 01-14-2012, 01:54 AM
stev's Avatar
stev stev is offline
Vehicle: 2001 Dodge Ram Van B2500 HD 1T
Trim Level: 12-passenger
Color: Military Army dark green
Rep:17
stev is on a distinguished road
Default ScanGaugeII in a Ram Van
Well, one of my gift from Christmas is a ScanGaugeII. It's a small little unit, but packs a great deal of info from the vehicle's computer (PCM OBD-II). For the Ram Van, that is 1998 and newer.
Realized that the van gets so-so MPG when the engine temp is below 170. Once above 184, the MPG jumps up really nice.
The unit plugs into the OBD-II plug just above the brake pedal. I have the cable zip tied securely and the unit sits above the radio trim piece.
This unit will also display the Pcodes and allow you to clear them.
There are other features too. It displays the TPS voltage, MAP info, RPMs, engine temp, IAT feedback,
Somehow, it knows the MPG and trip information all to well. It asks for engine size, fuel tank size and knows the injector flow to provide real time data for your MPG. It's very much right on for averaging it all.
JC whitney had these on sale. Look around for a deal.
PS, it can easily be transfer to another vehicle to check codes and clear them.
[b]2001 Dodge Ram Van B2500 Magnum 5.2L, 3.92, RoadMaster MKII-XXF[/b]
[b]2005 Dodge Caravan 3.8L SXT SnG[/b]
Old 01-14-2012, 10:06 PM
ramvan2500's Avatar
Trim Level: SLT - 2500
Rep:141
Lucky you, I have a 95 so I can't even connect a diagnostic tool. I have to do everything the old fashion way which sometimes is easier but it's sure fun.
Today I got to remove my transmission again and replace my rear planet and put the transmission back in fun fun. Drives better, still rumbling from rear end around 55 and higher but I know my drive shaft is a little off balance because the age.
