United Radio
Old 04-11-2011, 01:13 PM
ejk78 ejk78 is offline
Vehicle: 2004 Dodge Ram 1500
Color: Gray
ejk78 is on a distinguished road
Question Wheel alignment
Hey guys,
Just installed the leveling kit on my truck, i know i need the wheel alignment. Its says to use a shop that speclizes in trucks that are raised. Does anyone know if a "chain" like Firestone would work? Or do i have to search for a truck shop in the area?
Thanks
Don't go around....Com on its a RAM, just go OVER!!!!!
Old 04-11-2011, 04:37 PM
Steveo1's Avatar
Steveo1 Steveo1 is offline
Vehicle: 2008 Ram bighorn 1500
Trim Level: Bighorn
Color: Cool Vanilla
Rep:13
Steveo1 is on a distinguished road
I guess they could, what about your local Dodge dealer, my dealer installs lifts,level kits and works on modified trucks....you could ask, if they install Mopar lifts they can do it, but then again I would think any shop that can do truck alignments could do it...have it done soon or you could mess your tires up fast.
Old 04-11-2011, 04:43 PM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
That's where I'd go. (Good answer )
Old 04-11-2011, 04:54 PM
I agree...check with the dealer to see if they do them or if they put it out to a shop.
Old 04-11-2011, 06:44 PM
theweavman theweavman is offline
Vehicle: 2009 Dodge Ram 4X4
Trim Level: Laramie Crew Cab
Color: Austin Tan Pearl &Lt. Graystone Pearl
Rep:27
theweavman is on a distinguished road
My dealer said they couldn't do lifted trucks, so I took mine to a 4-Wheel Parts Performance Center...took care of it ---no problem...maybe there is one near you
So it is written ! So it shall be done!
Old 04-14-2011, 05:12 AM
Jmac86201's Avatar
Jmac86201 Jmac86201 is offline
Trim Level: Grey
Color: Grey
Rep:15
Jmac86201 is on a distinguished road
i had mine aligned after installing my leveling kit, but when i got the paper work back, the results still said there was some things not in the green and marked red being out of line while they were adjusted significantly, but im not sure if it is right. mine was done at pep boys, should i have it done again just to be safe?
Suspension, Tire, and Wheel Guide 57Hemi08 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 157 09-21-2014 09:47 PM
1/2 inch wheel spacer on 2010 4x2. Longer Wheel studs? cyberpine Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 23 08-12-2011 06:53 AM
steering wheel has slight cockeye after 3in BL Inferno Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 6 02-04-2011 04:13 PM
17" wheels off for new dodge. DODGE4x4 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 3 11-25-2009 03:28 AM
Wheel Choices - Get Your Vote On! erm Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 33 11-12-2009 04:56 PM
