Need tips for DIY dash and door bezel painting plz. - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Body & Interior
Old 04-11-2011, 01:05 PM
ramrat's Avatar
ramrat ramrat is offline
Vehicle: 2006 Dodge Ram SLT 4X4
Trim Level: SLT 4X4
ramrat is on a distinguished road
Default Need tips for DIY dash and door bezel painting plz.
I have an SLT that came stock with the woodgrain around the stereo and on each door above the controls. I think it looks cheap and doesn't match the rest of the truck at all. I'd like to have those pieces painted silver but I'm not sure exactly how to go about doing it. I'm also not interested in buying new bezels/panels/overlays unless I screw this up. haha!!!
I know that the doors and the dash are all one piece and I've read up on how to remove them prior to painting.
What kind of paint should I use?
Will it look cheaper than it already does?
What kind of paint is the most scratch resistent?
Should I prep the plastic prior to painting?
Is there anything that can be sprayed or applied over the paint after it's dried to help make it last and keep from scratching?
How long should it dry?
Any advice would be greatly appreciated. I'm going to try it out this weekend.
06' SLT Quad Cab 4x4 - 6" RCX - 18x10 Moto Metal 961's w/ -18 offset - 35x12.5 Nitto Trail Grapplers - Bilstein 5100's - Flowmaster 50 series - Chrome oval steps - KC HiLites behind grill - Nightrunner Headlights - Window tint - Kicker Hideaway - Kicker CS's all around
Old 04-11-2011, 07:29 PM
wermbang wermbang is offline
Trim Level: Sport- Off Road
Rep:1930
Adhesion promoter if your spraying plastic is a must. It helps paint stick to the plastic, or you can use paint that is for plastics
Old 04-21-2011, 09:07 AM
Dave07RamHemi's Avatar
Dave07RamHemi Dave07RamHemi is offline
Vehicle: 2007 Dodge Ram Quad Hemi
Trim Level: SLT Lone Star Ed
Color: sunburst orange
Rep:33
Dave07RamHemi is on a distinguished road
I used to do this for a living. Like wermbag states use an adhesion promoter. I do not understand if you are wanting to paint the wood parts or replace with original plastic and paint those. If so make sure they are clean, use soapy water and alcohol to clean and dry well, scuff with a scotchbrite pad and use an adhesion promotor, many of your AutoZone and Advance Auto parts store have those in the DFW area. a light coat of a primer and use a bumper primer if they have it. Several light coats, sand with 1000 wet sand paper and wash with soapy water rinse well and allow to dry. Then apply your paint. I would make sure you clear with a urethane which will make them pretty scratch resistant.
I get to DFW often if you want to meet and I can show you how
Chrome: door handles, pinstripe, nerf bars, Halo LED headlamps, line of fire, Lexani LX9000, Magnaflow, Volant CAI. color matching camper shell, 2009 Chrome door molding.
Old 04-21-2011, 03:08 PM
matt99 matt99 is offline
Rep:20
matt99 is on a distinguished road
Dave has it.
If you plan on painting plastic more than once, might as well buy a can of bullydog adhesion promoter.
Just sand with 600ish,800ish, then a good degreaser, then two light coats of the adhesion promoter, then a filler primer for the sanding marks (2 med coats), wet sand, then base (I do one light, then two medium), then I would go ahead and do a light coat of clear. After flash I would probably do at least two heavy clears (right before it runs) with at least 20min in between
Extra clear cant hurt and when you finish up by wetsanding and buffing you wont worry about sanding through. And a thicker clear will make it look glossier
[IMG]http://i294.photobucket.com/albums/mm110/swollguy99/1282248743-1.jpg[/IMG]
Murdered
Old 04-22-2011, 12:35 AM
Rep:3347
If you're just looking to change the color of the hard interior vinyl pieces, I'd look at a vinyl/fabric dye. Duplicolor makes a good product, I've turned my entire interior black using it and don't have any issues except where I'm constantly gouging the vinyl and it shows the stock color... but a quick spray with the can I keep in the truck and noone's any wiser. When using the dye, I use a good degreaser followed by a good scuffing with a green scotchbrite pad, rinse, and follow with another degrease and rinse. I use simple green.
It's easy to do, just takes time to do it, so set aside a full weekend where you'll have your interior pulled apart.
Old 04-24-2011, 10:53 AM
ramrat's Avatar
Trim Level: SLT 4X4
Thanks for all the replies and advice. I think I'm going to try a kit from carid.com or something similiar. I don't think I've got the talent enough to pull off a decent looking DIY paint job.
Old 04-26-2011, 06:00 PM
ICEMAN99TURBO's Avatar
ICEMAN99TURBO ICEMAN99TURBO is offline
Vehicle: 08 Ram
Trim Level: 1500 Big Horn
Color: Electric Blue Pearl
Rep:119
ICEMAN99TURBO will become famous soon enoughICEMAN99TURBO will become famous soon enough
Send a message via AIM to ICEMAN99TURBO Send a message via Yahoo to ICEMAN99TURBO
Send me the pieces, I will paint them for you... Prep work is a must.
Don't park in the ditch, that's not where you park, you park in a parking lot! .... Stupid!
