Old 04-11-2011, 04:17 PM
nitro1965 nitro1965 is offline
Vehicle: 2013 Ram Express 1500 Quad Cab
Trim Level: exspress
Color: cherry pearl red
Rep:27
nitro1965 is on a distinguished road
Default does dodge ram have issues with rear ends on there trucks ?
hello,
it seems to me that an awfull lot of dodge ram owners are having issues with the rear ends on there trucks as well as i . i have a 2006 4x4 5.7 hemi qc with a 3.92 lsd rear end. the other day i was driving down a hill were i live and i herd my rear end humming louder and suddenly the the back tires locked up. i could not move my truck , i then had to put it in 4x4 and put truck in reverse to back uo it then un locked rearend after a while. i took truck out of 4x4 and made it to garage very slowly . while on lift at garage the mechanic showed me where driveshaft goes into rearend there is a bearing and that bearing was toasted and the rear end was gone. i then had truck towed to dealer were they confirmed it and at this time a rebulit rear end is being installed in my truck under warrenty. it amazes me to hear about how many people are having issues with rear ends on there rams. does dodge realize this or are they doing something about this? even when i went to get a rental there was a brand new dodge ram at enterprise rental and they could not rent that ram to me because there is a recall on the rear end on that truck. they are still having issues.
Old 04-11-2011, 04:56 PM
I had a rough bearing and a wobbly u-joint that were replaced last year at about 48K miles. How many miles on your truck?
Old 04-11-2011, 08:59 PM
charlieb's Avatar
charlieb charlieb is offline
Vehicle: 2004 dodge ram 1500
Rep:31
charlieb is on a distinguished road
yup bigest problem is the lsd 9.25 rear ends (12 bolt cover) weak link is clutch pack clips.they fail often,redesigne for 2006-08 but still have some problems failing.the new ones only have a minor recall rear diff cover not holding enough oil.(need bigger diff cover with higher fill port)
Old 04-12-2011, 12:47 PM
Rep:27
maddog,
i bought my 2006 ram in 2009 and it had a little over 28000 miles on it. it came with the thunder road package. well from the begining i had issues with the rear end . when ever i took a turn and drove my driver side door would shake real bad and it was the result of the fluids in the rear end had to be changed and an addative had to be added to the new rear fluid. it took care of the shudder i call it for a little while . i then developed a leak where the drive shaft goes into the rear end seal . that was changed and fixed . i changed the rear fluid again at around 45000 miles because i noticed a slight shudder comming on again. i now have 58700 miles on my 2006 ram and a blown rear end. i spoke to the dealer and they expect the rebuilt rear end to come in on wendsday. i wonder if with this rebuilt rear end one they would correct the problems everyone seems to be having with these rear end?
Old 04-14-2011, 03:14 PM
Tominator223 Tominator223 is offline
Tominator223 is on a distinguished road
is this problem just with 1500s or all ? my 04 qcab has made noise since about 35000mi after dealer rebuit rear end that was @ 95000mi . i replace fluid & additive regularly @ 161000mi i did axle bearings. & adjusted pinion but still makes noise .thank goodness no more leaks have 194000mi now.was thinking maybe 2500 rearend ? i got stock 17s so dont care if rear wheels a bit different. or should i just go get a ford 9in . hiss hiss lol . i bought my truck with 3mi on it and it leaked from 18000mi to 95000mi til dealer finaly got it fixed. 5 trips
Old 04-15-2011, 10:59 AM
shocker's Avatar
shocker shocker is offline
Vehicle: 2003 Dodge Ram SLT (HEMI)
Color: Blue
shocker is on a distinguished road
I have had problems out of both dodges ive had. My 01 had a crazy moaning sound, found out it was the ring and pinion. My 03 has a pinion seal leak, hopefully its fixed now(fingers crossed). Other than that I have loved both trucks. Guess that in a couple years I'll by the 4th generation, which look badass. Hope they have the rearends fixed in those.
Old 04-16-2011, 04:29 PM
HemiLonestar's Avatar
Rep:261
I knew a guy back in 2004 who had an 02 or 03 that had gone through like 3 rear ends. This was surprising to me, since I had a 74 Monaco (a car) at the time with a 9.25 that most likely had never had its axle fluid changed in 30 years and never a problem. At 115,000 miles I haven't had any issues yet.
"Big Red"
2006 Charger R/T
Old 04-16-2011, 05:47 PM
Rep:2616
as was mentioned above, the 2010 - 2011 differentials fill/inspection hole was too low, the AXLE Bearings were not getting enough lubrication & seizing up
the fix is to put a hole in the rear differential cover that is high enough to let oil flow into the axle tubes, they are not drilling your old cover, they are sending out a replacement cover
I would be surprised if they were not sending the original cover out to get to get a hole drilled into them, then a plastic or rubber plug is inserted into the covers
I don't see why they are not putting a threaded drain hole & a magnetic plug into them at the same time, must be a cost thing
this is a low cost cover that is a direct replacement, that is built the correct way, at least to my thinking
[IMG]
http://stores.hi-potek.com/-strse-2/...ar-/Detail.bok
Old 04-17-2011, 11:50 AM
Rep:27
well i finally got my truck back from the dealer. they ended up replacing the entire rear end with a rebuilt one by jasper. has anyone ever herd of a rear end being built by jasper ? are the rear end any good ?
Old 04-17-2011, 12:03 PM
charlieb's Avatar
Rep:31
your rear end is likely same as oem with oem corporate 9.25 lsd parts because its done by dealer.others have changed out to auburn or detroit.you need to keep on top of maintenance with 9.25 rear ends syn fluid change every 15-30k depending on wether your towing.other rears go 50-80k between changes with no problems.the 2500 used dana rears not corporate but they are 6 stud might look funny on back with 5 on front to answer other question up top.
New Recall k36 found it today at Dodge dealer - REAR AXLE FLUID DRAIN-BACK FLOW RESTRICTOR - Pic RAMTX 2011 Dodge Ram Forum 131 09-23-2011 11:36 PM
Rear Axel Fluid Recall 2011 Dodge Ram 1500 E220 Dodge Ram Recalls and TSB's. 27 03-14-2011 11:51 PM
husky weatherbeater rear floor mat, dodge ram crew in michigan semichigan Dodge Ram Parts and Accessories for Sale - Trade - Want To Buy! 9 12-29-2010 01:10 PM
new to this site and Dodge trucks fasteddie2 Newbie Checkin! 13 06-08-2010 02:23 PM
'98 Dodge Ram rear end bearings Quiet Lunatic 5.2L V8 Specific Topics 1 06-06-2010 11:59 PM
