Old 04-11-2011, 03:23 PM
embry1123 embry1123 is offline
Vehicle: 1998 Dodge Ram
Trim Level: Laramie SLT
Color: Blue
embry1123 is on a distinguished road
Default 1998 trans issue
Hey everyone. My son just got his first truck, a 1998 1500 4x4, 5.2 automatic, Laramie SLT. The trouble is that the trans is in the bed of the truck. We know the previous owner and he said when the trans first started acting up it wouldnt shift unless he let off on the gas, then it got to where it wouldnt shift at all. He is no mechanic, but he started throwing parts at it, said he spent a bunch of money replacing all of the external electronics on the trans to no avail. From what I have read the trans is a A518/46RH-RE. Not sure which though (RH or RE). Is there an easy way to tell them apart? Also, I will be rebuilding the trans completely because I did not get to drive the vehicle to see what it was doing first hand and don't want to put it back together on a prayer. Is there anything in particular that I should look for? Ive read about "spring" behind the front pump and some other things, but really am just trying to get a very thorough idea on this thing. ANY suggestions are appreciated greatly!
Thanks-
Old 04-11-2011, 09:37 PM
frealz13's Avatar
frealz13 frealz13 is offline
Vehicle: 2001 ram 1500 4x4
Trim Level: slt laramie
Color: blue silver
frealz13 is on a distinguished road
pretty sure its a 46re mine was shifting funny and i ran the piss out of it and now she runs fine good luck
-PAT-
Old 04-11-2011, 10:06 PM
94ram1500's Avatar
94ram1500 94ram1500 is offline
Vehicle: 1994 Dodge Ram
Trim Level: SLT Laramie
Color: Green
Rep:139
94ram1500 will become famous soon enough94ram1500 will become famous soon enough
When I rebuilt mine, I bought this trans rebuild kit
http://shop.advanceautoparts.com/web...AMS_1323637965____
the listing shows it for both the A518 (46RE/RH) and A618 (47RE/RH, 48RE)
It has everything you need as far as steels and friction clutches, seals and o-rings. I needed hard parts for my overdrive. Unless you have a press and the proper tools, the average DIY'er won't be able to replace the clutches in the overdrive unit.
You can find some info from the pdf files here:
http://openpdf.com/ebook/46re-service-manual-pdf.html
good luck,
Ed
Can someone please tell me, why common sense is so uncommon these days??
Old 04-17-2011, 06:20 PM
Ram Tough's Avatar
Ram Tough Ram Tough is offline
Vehicle: 1999 Dodge Ram 1500 Sport 4x4
Color: Primer Gray
Ram Tough is on a distinguished road
The 46rh meaning hydraulic has a 3 pin plug for the solenoids as the 46re electronic has multiple pins because of the gov. Just look at the solenoid plug that will tell you...
Trans rebuild 94ram1500 5.2L V8 Specific Topics 4 04-07-2011 09:49 PM
Gotta Trans Issue Burkdadhemi 5.2L V8 Specific Topics 2 02-09-2011 08:14 AM
Superchips trans issue MGram 5.7L (345 cu in) HEMI V8 Specific Topics 22 11-27-2010 12:44 AM
1998 Ram 1500 wheel hop issue wyldelee Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 1 03-24-2010 06:05 PM
1998 trans. stick 5 sp. in 1997 1500 2 WD. WM300 V6 Specific Topics 0 02-26-2009 12:20 AM
