Old 04-12-2011, 11:10 AM
I push the skinny pedal
Rep:3277
Looking good kay9! I had to give up my 6.1L manifold, needed $$ for other things (pics will be soon), but it looks like you've done a great job with the install, and the LMI is a very beautiful intake.
Kurtis
Old 04-13-2011, 01:57 AM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
I didn't realize you did the 6.1 intake..looks badass man...Did you do all the work at Mike's...
5.7 e.t.'s: 1/8 - 7.85@93.20, 1/4 - 12.10@113.96 juice - 12.96 NA... 6.4 e.t. 12.59@106 NA
Old 04-13-2011, 09:51 AM
TheSatinPumpkin's Avatar
Vehicle: 2004 Dodge Ram
Color: Satin Orange
Rep:597
Thanks. Yep a good 18hr install session at Mikes. Lot of F this and that in the final hours LOL.
Left 3am Sun and Chris did a 6.1 manifold on a 09 later in the day.
Everything Done there
hemifever 216 base/crank up tune
Crane 216 @ 112lsa
6.1 Manifold Conversion
6.1 Ignition Conversion
EGR Delete/ Block Off
Inertia Motorsports Big Valve Heads milled @ .020"
New Retainers and 6.1 Springs/Pushrods
Modern Muscle 5.7/6.1 Adapter Plates w/ Thermal Gaskets
NGK 4306 Plugs
LMI Hammer Design CAI
Mark VIII E-Fan (done earlier)
Moes Coolant Overflow Tank
Still needing to go in over time.
Hemi Coil Covers
SS Braided Lines (Have sleeves but may go the full replacements)
Painted Battery and Fuse Cover
Billet Caps
Extensive wire management
May paint alt and A/C gloss black
This will take care of my project in giving the bay a well deserved make over.
Old 04-13-2011, 10:45 AM
Color: Satin Orange
Rep:597
Its pretty much bolt on. Stu's 6.1 Relocating Brackets are meant to be bolt on but we had to do quite a bit of trimming to access the manifold TB holes. You will have to convert over to 6.1 ignition setup and modify your wiring harness to fit the 6.1 coil packs. You will also need to remove your EGR and if you don't have one then you would need a shroud-less e-fan setup and a new coolant overflow tank.
Also there is a port mismatch due to pre eagle heads. You will have to port match your heads to the intake or use 5.7 heads to 6.1 intake adapters. I went with Modern Muscle Adapters. Also thermal gaskets to deal with heat soak.
Buying everything could be up to 2k-2500 for changing out the manifold and thats just keeping your stock heads and cam. I got a great price on a FULL 6.1 manifold and ignition setup. Same with the BV heads and cam.
I'll update more later as there are quite a bit of parts you need from different places.
Originally Posted by Silver04Ram View Post
I too would like to clean up the engine bay on my truck and that looks very clean. I am running nitrous already so that would be helpful too. Just wasnt sure how costly it is or how much work goes into doing it ie what else do you have to do or change to get it to work
Old 04-13-2011, 10:50 AM
GeauxHunting's Avatar
Vehicle: 2005 Dodge Ram 1500
Rep:1338
Looks awesome man!!! Thanks for the pictures. Thar carbon fiber is hot
Dillon-aka, The Little Kid
Old 04-13-2011, 12:58 PM
Color: Satin Orange
Rep:597
Thanks. It touch the belt first so we adjusted the clamps until we got over a inch clearance. I would like to get a coupler and extend it out a little more and angle it down more to get more direct cool air but its working out good.
Love it and completely took away my desire for a BFI LOL.
Old 04-17-2011, 02:31 AM
antman182 antman182 is offline
antman182 is on a distinguished road
If they started making these for the normal 5.7 engine, BFI and all that headache would quickly be a name that people could forget.
Bfi new intake moparmike07 Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 1531 07-08-2011 12:35 AM
02-05 carbon fiber factory dash pieces on ebay 05atlanticblue Custom Dodge Ram Interior Modifications - Custom Audio / Video 2 12-08-2010 10:31 AM
Carbon Fiber Hood syrupdawg Custom Dodge Ram Exterior Modifications - Body Mods - Body Kits 10 11-11-2010 12:28 PM
Interior carbon fiber mod - cover stock chrome GilmoreTruck Custom Dodge Ram Interior Modifications - Custom Audio / Video 13 08-18-2010 04:41 PM
Custom Insert for Cab/ Carbon Fiber JBSPartans05 Dodge Ram General Discussion 29 11-23-2009 11:31 PM
