Old 04-12-2011, 10:34 AM
BigHornRam2006's Avatar
BigHornRam2006 BigHornRam2006 is offline
Vehicle: 2006 Dodge Ram 1500
Trim Level: SLT Big Horn Edition
Color: Patriot Blue Metallic
BigHornRam2006 is on a distinguished road
Default New Rotors Installed / Shaking from the rear
About a few months ago, February I think, I installed new brake rotors which are cross drilled and slotted and new brake pads which are ceramic. However, when I hit the brakes the truck tends to shake from the rear end. The truck has been doing this before I swapped out the rotors and brake pads. Has anyone else had this issue?
Dan R.
SGT, US Army
2006 SLT Big Horn
Old 04-12-2011, 10:39 AM
I've never experienced this. Any shaking or vibration I've experienced with the brakes was in the front and due to a loose caliper, worn pads, a warped rotor, etc....
I'd check the caliper to make sure it's tight, check caliper operation (one person pushes brake pedal while another verifies operation), pull your pads and inspect them, check rotor run out.
If you eliminate the brakes as the root cause, move on to checking the rest of the suspension fasteners to make sure it's all tight.
Have you inspected/replaced your rear shocks?
Old 04-12-2011, 10:44 AM
No, I have not replaced my rear shocks. Right now my truck is sitting at just over 61,000 miles. Right now I am trying to gather the money to get the Bilstien Shocks. But I know I am in dire need of shocks all around.
Dan R.
SGT, US Army
2006 SLT Big Horn
Old 04-12-2011, 10:56 AM
That may be part of the problem but I can't be sure.
Old 04-12-2011, 01:02 PM
Wildcat's Avatar
Wildcat Wildcat is offline
Vehicle: 2010 Dodge Ram QC 4x4
Color: Mineral Gray Metallic
Rep:166
Wildcat has a spectacular aura aboutWildcat has a spectacular aura about
Just throwing out ideas here, but could a worn u-joint or pinion bearing cause this? It could still be functional, but the momentum pressing forward when on the brakes could compress a failing junction and cause this. When you crawl underneath to check out the suspension, you might grab the driveshaft and make sure it is tight with no slop.
Cobra CB, Dual antennas, Dodge molded splash guards, Tekonsha P2 brake controller, Weatherguard tool box, AirLift 1000 helpers springs, Line-X bedliner, B-Pillar tape removed, 35% tint front windows.
http://i842.photobucket.com/albums/zz347/kcwildcat1/Wildcatsig.jpg
Double Din installed with rear view camera olsarge Custom Dodge Ram Interior Modifications - Custom Audio / Video 19 04-27-2011 04:46 PM
does dodge ram have issues with rear ends on there trucks ? nitro1965 5.7L V8 Specific Topics 9 04-17-2011 11:03 AM
Rear End SHOT! BOSS 32V 5.7L V8 Specific Topics 3 03-25-2011 03:20 AM
Shaking in rear end? Xxbrittox Suspension 10 10-20-2009 07:26 PM
SRT8 Rear Fascia Installed... DaveDees Other Vehicle Discussion 3 11-15-2008 07:45 PM
