View Poll Results: 482(9+3) = ???
288 133 46.34%
2 154 53.66%
Voters: 287. You may not vote on this poll
Old 05-14-2012, 11:48 AM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
wow lol.
The order of operations is just like was stated above:
Parenthesis, multiplication and divison(left to right), addition and subtraction(left to right).
Or google it...
The correct answer is definitely 288.
Sean
Old 05-30-2012, 02:45 PM
LeftCoast's Avatar
LeftCoast LeftCoast is offline
Vehicle: 2012 Ram
Trim Level: Sport Crewcab
Color: True Blue Pearl
Rep:248
LeftCoast has a spectacular aura aboutLeftCoast has a spectacular aura aboutLeftCoast has a spectacular aura about
Originally Posted by mbehlok View Post
If you google for "482(9+3) =" It comes back with an answer of 288.. And we all know that google is never wrong.. haha
yup and the calculator on my phone gives the same answer. 288.
Probably the only 2wd Blue Crew in Canada.
Mod list Debadged, Airlift 1000 airbags, Cabin Air Filter Mod
, BT Catch Can.
Old 05-30-2012, 10:42 PM
HotWheels's Avatar
HotWheels HotWheels is offline
Vehicle: 2010 Dodge Ram 1500 Crew
Rep:43
HotWheels is on a distinguished road
Ha ha. This is awsome.
Old 06-19-2012, 02:20 PM
BEX2010 BEX2010 is offline
BEX2010 is on a distinguished road
PEMDAS!? I got 2!
Old 07-17-2012, 04:08 AM
ArtNJr ArtNJr is offline
Vehicle: 1998.5 Dodge 2500HD 4x4
Trim Level: SLT Laramie
Engine: 1998-1998 359ci (5.9L) Cummins ISB 24-valve Diesel I6 235hp 420lb/ft (manual), 215hp 420lb/ft(auto)
Rep:57
ArtNJr will become famous soon enough
Originally Posted by davidonmars View Post
saw it on other car forums and alot of people seem to think its 2 so i wanted to see what you guys thought
It is 2
You do the calculation inside the parentheses 1st & that number is multiplied by the number next to the parentheses:
482(9+3) = ???
That translates to 482x12, or 4824
which of course = 2.
Or, put another way, the problem is 48 divided by what? You have to figure out what the what is 1st !!
"One of the problems with 'majority rule' is the majority is usually wrong." -- Thomas Jefferson
Old 07-17-2012, 08:02 AM
snrusnak's Avatar
Rep:1385
It is 2
48÷2(9+3) = ???
That translates to 48÷2x12, or 48÷24
That's incorrect.
48÷2(9+3) = ?
48÷2*12 = ?
24*12 = ?
= 288
Order of operations is parenthesis, multiplication and divison(left to right), addition and subtraction(left to right).
You went right to left with multiplication and division.
Sean
Old 07-17-2012, 08:52 AM
Rep:57
That's incorrect.
482(9+3) = ?
482*12 = ?
24*12 = ?
= 288
You're trying to do it like reading a sentence (is that the "new math"?), but the math & the description still don't match.
As a math professor commented in an article on the problem (I didn't realize it had been around on the 'net for a while), you wouldn't write an equation that way anymore, but this is what it boils down to:
the number to the left of the division sign is a whole number -- you do not need to go thru any steps to find out what it is, and that number (48) is to be divided by (not into) something. But the something is a calculation which has not yet been finished, so you have to finish it first.
Written this way it's easier to see:
48
_______
2(9+3)
Or, you could write it like this:
48 a = x
a = 2(9+3)
What is the value of x?
Obviously you have to figure out what "a" is first!
Whenever there's a whole number on one side (be it left or right) of an operator (+, -, x, or ) & an unfinished calculation on the other side, you have to do the unfinished calculation first.
Old 07-17-2012, 09:17 AM
snrusnak's Avatar
Rep:1385
It's not "new math", it's standard order of operations, based on how it's written.
It wasn't written as:
48
_______
2(9+3)
You're using implied multiplication to solve, which isn't really wrong, but it doesn't follow standard order of operations, which generally takes precedent. It's really open to interpretation, but if you strictly follow standard order of operations the answer is 288.
Nobody would ever write an equation like that though(other than for a purpose like this) because the use of the division sign in equations causes confusion on order of operations.
Sean
Old 07-17-2012, 09:55 AM
Rep:57
It must be "new math". Note the difference in our ages (upper section of messages) -- I went to kindergarten, grade school & high school 1958-1971, then to 2 universities after that & by the time you were born (my son is 1 year older than you) I was the engineer in a small custom manufacturing facility, doing all the design work, making all the prototype parts & designing, building, installing & teaching operators to run various types of production machinery. Which of course I wouldn't have been able to do if I couldn't do a simple math problem!
48
_______
2(9+3)
But both ways the equation means exactly the same thing. It's 48 divided BY, not INTO.
The way I was taught is the way I described -- when there's a whole number on one side of an operator & an unfinished calculation on the other side you finish that calculation first. Always, always, always. Because if you don't you'll get different results from the same equation -- exactly the problem we're talking about !!!
About the time I finished high school (1971) people were talking about the "new math", whatever that was -- I was never taught anything different in college either. But then again, I haven't taken a college course since 1979.
Old 07-17-2012, 11:15 AM
Rep:57
Here ya go -- I happened across this site on the "PEMDAS Rule":
http://www.mathsisfun.com/operation-order-pemdas.html
From that page:
_______________________
"Order of Operations - PEMDAS"
when you see something like ...
7 + (6 5^2 + 3)
(5 squared -- can't type the 2
slightly above & to the right of the 5)
... what part should you calculate first?
7 + (6 5^2 + 3)
7 + (6 25 + 3) Start inside Parentheses, and then use Exponents First
7 + (150 + 3) Then Multiply
7 + (153) Then Add
7 + 153 Parentheses completed, last operation is an Add
160 DONE !
Same thing there as I was trying to explain -- the whole number 7 is NOT part of the equation until AFTER the unfinished part has been completed.
