Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 2nd Gen Dodge Ram Heating & Cooling Problems and Questions.
Dodge Ram Decals
Old 04-13-2011, 04:19 PM
NCDEVILDOG's Avatar
NCDEVILDOG NCDEVILDOG is offline
Vehicle: 2001 Dodge Ram
NCDEVILDOG is on a distinguished road
Send a message via Yahoo to NCDEVILDOG
Default AC/Heat Issue
okay, so to the least this problem is very annoying. To begin my truck is a 2001 ram 5.9 4x4 offroad.
The problem: I turn the defroster on (either heat or cold) and it switches to either one randomly. If I put it on cold, it goes to cold for a minute or two then switches to hot by itself. It mostly goes to hot when I brake. However, the cold is really cold, and the hot is really hot. It just cant make up its mind I guess between the two. It has been doing this for about a year now. I just never used the air or heat til recently.
Within the past 2 weeks it has started smoking alittle through the vents(no matter what position I have the selector in) I can smell engine coolant, so I am thinking my heater core is either plugged or maybe leaking somewhere. I did check the carpet on the floor and cannot find any wet spots.
On a side note; I did replace the radiator about a month ago.
I have also heard about the blend door axle breaking, causing the door to not stay open or closed. any help is greatly appreciated. thanks guys
semper fi to all my brothers out there!
Old 04-13-2011, 11:13 PM
ramvan2500's Avatar
Trim Level: SLT - 2500
Rep:141
Smile Check your core...
You should certainly check your heater core along with some other things. I can only help so much but just check your core.
Old 04-14-2011, 12:47 AM
Vehicle: '09 Ram 1500/'16 Ram Ecodiesel
Rep:2875
all heater & AC systems are basically the same
a good site to check out has information & videos & trouble shooting
http://www.heatertreater.net/Dodge%20Product%20Page.htm
Old 04-14-2011, 01:00 PM
NCDEVILDOG's Avatar
I am going to bypass the heater core tonight and see if the smoke coming through the vents and randomly changing temperatures stops. If it does, atleast I'll know its the heater core without having to rip my dash apart. Losing the heat isnt really a big deal since Im moving to Arizona soon.
Old 04-16-2011, 01:28 AM
ramvan2500's Avatar
Rep:141
Good point but the heater core isn't in the dash I don't believe. I believe it is in a black plastic box that has the A/C Evaporator as well as the Heater Core. I may be wrong because different trucks years designs etc... But it sounds like it could be the heater core. I don't have heat problems LOLOLOLOL but A/C problems and I live in Florida. But about your problem I can only tell you so far to check the core. Best of luck
Old 04-16-2011, 04:37 PM
NCDEVILDOG's Avatar
So here is an update. I was looking under the hood around the accumulator, and noticed that directly underneath it is a tube of some sort coming through the firewall. This is dripping antifreeze/coolant from it. Not too bad, maybe a cup every couple of days. The truck is running good. I only have the above stated issues with the ac system. Ive been looking in my haynes manual to try and figure out what this tube is, but cant find it anywhere. Does anyone know what it is? also, is there supposed to be a hose going to it? I did not find any lose hoses anywhere. thanks guys.
**EDIT**
So, after some more digging; from what I understand, this thing is called a fixed orifice tube? I do not know anything about it, but could only find a couple of posts on here about replacing it if it is clogged. What does it do? I cant find anything describing its purpose and or if it is supposed to have a hose connected to it so it doesnt leak coolant. thanks guys.
Old 04-18-2011, 04:06 PM
NCDEVILDOG's Avatar
No one has any ideas?
air conditioning, coolant., defrost, heat, smoke
Automatic Start Issue / Check Engine Light 07Ram 5.7L V8 Specific Topics 4 05-19-2011 06:46 PM
RUST issue with 2010 4x4 Ram Big Horn...anyone else having this issue SupermanWV 2010 Dodge Ram Forum 18 01-29-2011 10:42 PM
Vibration Issue WickedSix 5.7L V8 Specific Topics 5 01-13-2011 12:30 AM
AAC Interior Light issue Quiet Lunatic Custom Dodge Ram Interior and Exterior Lighting 8 06-01-2010 08:58 PM
Dealer issue, being a baby or honest issue. cartert1975 Dodge Ram Dealer Issues - VIN and Order Tracking - Dodge Ram MSRP & Pricing Discussion 31 04-09-2010 02:19 PM
