Brake light wiring help - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Electrical
Old 04-13-2011, 05:30 PM
theweavman theweavman is offline
Vehicle: 2009 Dodge Ram 4X4
Trim Level: Laramie Crew Cab
Color: Austin Tan Pearl &Lt. Graystone Pearl
Rep:27
theweavman is on a distinguished road
Question Brake light wiring help
I'm planning on adding an additional brake lamp....I have been trying to determine the best way to connect it.
Does anyone know if there is a pin on the trailer wiring connector, that is activated by the brake lights? I don't want my added lamp to flash with the turn signals.... I figured that if worse came to worse, I could make my connection at the under hood fuse panel, or wire it to the above the cab brake lamp,(if I can find where the wires go) but both would require a long run of wiring...figured there must be a better way or location to tap into... I also found a converter for towed vehicles with seperate brake and turn signals, that I believe I could use, but it's about $30.00...If anyone has any ideas, or suggestions...please let me know...I was wondering how those towing receiver caps, the ones that have a brake lamp in them, are wired in?....Thanks
So it is written ! So it shall be done!
Old 04-14-2011, 12:12 AM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
Good set of questions, where are you wanting to attach or install these extra lights? Yes, one of the pins on the trailer connection would work, but, I couldn't tell you which one. Someone will though.
Old 04-14-2011, 08:59 PM
Rep:27
Thanks, I don't think I can connect to the trailer wiring connector, without the new brake lamps flashing with the turn signals...I'm adding three small led lamps above my rear license plate, in the recess below my tail gate, looks pretty good, just have to get them hooked up and working
Old 04-17-2011, 04:29 PM
brad12kx's Avatar
brad12kx brad12kx is offline
Vehicle: 2010 Ram 1500 QC
Rep:2581
The available connections at the trailer plug are -
Tail Marker (park lamps)
Left Turn/Stop - Flashes with Left turn
Right Turn/Stop - Flashes
Reverse light
Electric brake signal (Variable voltage) - Only available with brake controller
+12V accessory (also charges the trailer battery)
Ground
None of the wiring supports brake light only.
However, the white wire on the back of the trailer brake controller (or trailer brake controller connector if you don't have the controller) has the signal your looking for. It has +12v when the brake lights are on.
brad
Interested in one of my mods?
Old 04-17-2011, 05:35 PM
Rep:27
Thanks for your reply and info, after trying a converter used by makers of camper shells to work the brake lamp in the camper shells, which did not work on my truck, I was told about a white wire, which hangs above and to the rear of my spare tire location... If you have the factory tow wiring... Anyway, it is made expressly for the purpose of supplying a BRAKE light only electrical source.... I connected to this wire, and all is working just fine now, too bad Dodge doesn't tell us some if these things in their owners manual, we have to find some of this stuff out by trail and error
Old 04-17-2011, 05:45 PM
brad12kx's Avatar
Rep:2581
That is really good information! Thanks for sharing.
brad
Old 04-17-2011, 05:58 PM
Rep:2964
If you can read a wiring diagram, look at this website
it covers 2004 - 2011
choose your year, model, then your particular cab type
a list will pop up, open the Wiring Diagram
http://www.dodge.com/bodybuilder/year.pdf
brake lamps, wiring schematics
How-To: Add Factory Fog Lights mjonesjr Dodge Ram Knowledge Base 20 12-13-2017 06:32 AM
interior lights in 98 ram 1500 lacamu Custom Dodge Ram Interior and Exterior Lighting 6 08-12-2011 02:43 PM
abs light, brake light, speedo not working, stalls when stopping B and B LANDSCAPES Electrical 21 04-07-2011 09:56 PM
Early 3rd Gen LED Tails and Third Brake Light jcasey10 Dodge Ram Parts and Accessories for Sale - Trade - Want To Buy! 3 01-04-2011 03:53 PM
Third brake light causing the brake lights to stay on? Due Electrical 7 05-19-2010 02:33 PM
