Old 04-13-2011, 08:07 PM
nhart713 nhart713 is offline
Vehicle: 2001 dodge ram 1500 4x4
nhart713 is on a distinguished road
Default having catalic converter problems
i have now replaced two that were defected. they offer me a new but i'm wondering if gutting that cat will be better and how much does it effect in the long run
Old 04-13-2011, 09:01 PM
i was wondering if they got a bad batch or what they don't know whats going on took it to a mechanic and he said everything seemed fine engine and exhaust wise beside that
Old 04-13-2011, 09:10 PM
also if i did gut the cat since it dies have pre o2 sensor and post o2 sensor will it effect that.
Old 04-17-2011, 05:31 AM
jcasey10's Avatar
jcasey10 jcasey10 is offline
Vehicle: 2002 Dodge Ram
Trim Level: SLT Quad Cab
Rep:869
If you're running a gutted cat, you're going to throw a code. The O2 sensors will pick up that you don't have a cat, and send that info to the pcm. If you're looking for more exhaust performance, you might look in to a hi-flow cat from Magnaflow with a good y-pipe and some good mufflers.
Old 04-17-2011, 02:17 PM
Gutting the cat will create a code.
What I don't understand is why were the cats considered defective?
Are you getting any codes now? Or did you? If so, what were they? You might have an intermittent failure of one of the O2 sensors.
Old 04-18-2011, 08:51 PM
that was the weird thing they did throw a code but both of them actually started to break up inside. i'm not sure why but it did
Old 04-19-2011, 02:32 AM
dodgeram02's Avatar
dodgeram02 dodgeram02 is offline
Vehicle: 2011 Dodge Ram 1500 Quad Cab
Rep:59
dodgeram02 will become famous soon enough
if you remove your cat, you will lose alot of low end. i know this because i dont have my cat. and if you go to napa or whereever and ask for non foulers, you will need an 18mm. i think the dorman help series number is 42009. you will have to hold onto one of them with vice grips and drill about a 1/2 inch whole so part of the o2 sensor will stick thru to meet the threads. if you put the o2 sensor in the one you drill a whole in and then that one into the one you didnt modify and screw this into ur o2 port you will be fine. it will move the o2 far enough out of the way u wont get a code. all the rear o2 does is say if the cat is working, so ur just moving out of the direct exhaust. i think it cost me like $8. sure beats the o2 dummy sims that fastman sells.
"I dont lie to my wife about my truck...I dont lie to my truck about my wife, they both know, no matter how good they treat me I'm still going to get on the other one"
Old 05-03-2011, 10:44 AM
brains06 brains06 is offline
Vehicle: 2008 Ram Quad Cab
Color: Blue
brains06 is on a distinguished road
Sorry for making this my first post but I wanted to know if this fix allows the truck to make the low end power again or if it just gets the light off.
Old 05-12-2011, 08:52 AM
bigjeff64's Avatar
bigjeff64 bigjeff64 is offline
Vehicle: 2001 Dodge Ram Quad Cab
Rep:20
bigjeff64 is on a distinguished road
i have a 2001 w/ the 5.9 and i do not have an o2 sensor on teh exit side of my cat
leveling kit problems? jaybull Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 12 10-27-2014 11:32 AM
Calalytic Converter Woes vsanks 5.2L V8 Specific Topics 14 07-28-2011 10:02 AM
Converter Problems jusmisdit1 Exhaust 4 09-15-2010 03:40 PM
catalytic converter CanadianInfernoRed 2010 Dodge Ram Forum 1 05-17-2010 12:25 AM
87 Ram 318 Engine Installation Problems mbridge1 5.2L V8 Specific Topics 3 12-04-2009 08:04 PM
