Old 04-14-2011, 12:09 AM
sparks11's Avatar
sparks11 sparks11 is offline
Vehicle: 2011 dodge ram quad cab v6 3.7
Trim Level: st
Color: hunter green
sparks11 is on a distinguished road
Default After market wheels on a 2011 st ram
hi guys, was wondering if getting after market wheels would screw the truck
you know shocks/struts/ alignment, and bumpy.
a friend of mine has 24's on a taho and it drives terrible!! you can feel the bumps on the stering wheel, wondering if I install 22's on my ram am I going to srew it up?? my ride is a st and have stock wheels, I alreday tried wheel covers but they fall so wheel covers are not a really good option bur at the same time I feel kind of scared to install after market wheels, I heve seen and heard how those wheels can really screw up your ride, please advise me on this one.
thanks!
Old 04-14-2011, 08:47 AM
Rkeytek's Avatar
Rkeytek Rkeytek is offline
Vehicle: 2011 ram 1500
Rep:210
Rkeytek has a spectacular aura aboutRkeytek has a spectacular aura aboutRkeytek has a spectacular aura about
Aftermarket wheels themselves wont harm your truck, if you go larger than 20" rims you have less rubber around them and you will feel more of the bumps in the road, there is also more of a chance you will bend a rim and wear out your struts pre-maturely.
Another thing to watch for is the wheel width and back spacing so that your new meats aren't going to rub your fender or suspension parts.
I know here in NYC i will not go for less rubber anymore, on my old Mazda 6 I got bigger rims and lo profile tires and every rim ended up bent at some point!
Some of the roads here are worse than the back country roads when I go camping serious!
Old 04-14-2011, 10:37 AM
Actionjackson's Avatar
Actionjackson Actionjackson is offline
Vehicle: 2013
Trim Level: EXPRESS
Color: WHITE
Actionjackson is on a distinguished road
i have 24's on mine last 4 trucks i have had i put 24's on it and never had a problem.
Old 04-14-2011, 12:18 PM
sparks11's Avatar
Trim Level: st
Color: hunter green
thanks guys! I think I will go with 20's that way I will have more cushion on the bumps, my truck has 17's and the ride is very smooth, I would not mind having 17's but 20's seem to me is not very different it's only 3' I will not lose much rubber.
Old 04-14-2011, 12:36 PM
JimmyNichols's Avatar
JimmyNichols JimmyNichols is offline
Vehicle: 2011 Ram 1500
Color: Mineral Gray
JimmyNichols is on a distinguished road
The higher trim packages come standard with 20's, so that should be a good choice.
Old 04-14-2011, 12:41 PM
GeauxHunting's Avatar
Vehicle: 2005 Dodge Ram 1500
Rep:1338
You should be good with 20"s. You will have a good bit of rubber still.
Dillon-aka, The Little Kid
Old 04-14-2011, 02:05 PM
sparks11's Avatar
Trim Level: st
Color: hunter green
thanks guys!
Chrome Clad OEM wheels harleysarge Dodge Ram Wheels And Tires 8 11-17-2013 08:13 PM
Torque Thrust D wheels RumbleBee08 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 10 07-02-2011 06:52 PM
2011 wheels on an '02 rex450se Suspension 2 02-05-2011 02:04 AM
2011 4x4 Front wheels won't properly papasmurfor9 Dodge Ram 4x4 - Offroad Discussion 10 01-26-2011 12:29 PM
Which wheels? jcasey10 Dodge Ram Wheels And Tires 9 09-28-2010 09:28 PM
