Old 04-14-2011, 08:46 PM
RamRod07's Avatar
RamRod07 RamRod07 is offline
Vehicle: 2007 Dodge Ram 1500
Rep:15
RamRod07 is on a distinguished road
Default What next?
Hey guys I need some ideas. I am wanting to do more to my truck performance wise but dont know what to do. I have a Diablo Predator, Flowmaster exhaust, and K&N Cold Air Intake. I'm planning on a throttle body spacer but besides that I dont know what to do. I've looked at superchargers, those trick flow harmonic balancers, and nos. I know that diesels are using these new nitrogen injection systems and they work awesome my buddy has one. I wasnt sure if this would help my truck since its a gas. I hope it does because it produces its own nitrogen and dont have to fill a bottle like nos. Any advice or suggestions would be greatly appreciated! Thanks!
Old 04-14-2011, 09:32 PM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
You'll get some great answers for the HiPo desires. I don't have experience with any of what you're looking for.
Hi, a big HELLO and a warm Carolina Welcome. I hope you make the most of the ForumZ! We do like photos so I hope to see some from you soon!
How about joining our Red RAM group? http://www.ramforumz.com/group.php?groupid=24 and drop by the Newbie Checkin (link below) for a quick introduction?
Old 04-14-2011, 09:39 PM
ScatPak07's Avatar
Rep:970
I would scrap the throttle body spacer unless you are going to get a supercharger or turbo. If you want to do it right wait on the forced induction and do the motor. If you want to really open her up then get a set of long tube headers (Dynatech makes very good headers), a new cam and some ported heads (cam and heads Inertia Motorsports). Those upgrades will add at least 60hp. Then you could look at the pulley like you were talking about, an electric fan and the NOS. Only thing about the NOS is that you can only use it so much then you need to refill the bottle. I would suggest going with the Zex kit since they make one specific for the Ram. It also is activated by the throttle rather then a button which is great. After doing the motor adding a supercharger would really make it a beast.
Little things like a ported throttle body, a throttle body spacer would work the best with forced induction.
Old 04-14-2011, 09:51 PM
I would forget about the TB spacer, decide if you wanna go all motor, a power adder or forced induction, then take your choice forward.
NOS is quick and easy, forced induction is a bit more complicated and of course, building a motor takes a bit more. The issue with the 5.7L Hemi that a lot of folks have run into is that too much NOS or too much PSI tends to result in ring land failure and eventually engine failure.
So, regardless of which way you go, you are still going to be building the motor for your power choice (or rebuilding the motor as the case may be ) to get more power.
Not sure how big you wanna go but you could go with a cam, a little head work, headers and high flow cats which will be a nice step up.
Good luck with your mods!
Old 04-15-2011, 01:10 AM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
if you wanna go motor...
cam, heads,cai, headers, cat deletes, new Y or true dual's, ditch the flows for anything better, diablo, efan, 180 tstat, u/d pulley, tq verter, shift kit, gears...
if you not happy with that then spray or forced induction..
-fast freddie- one quick 05 hemi qc...with over 275k miles on odo... on the 5.7, stoker 6.4 now...Inertia Motorsports 392 stroker
Old 04-24-2011, 12:12 AM
moparmike07's Avatar
moparmike07 moparmike07 is offline
Vehicle: 07 dodge ram 1500
Trim Level: st
Color: silver
Rep:68
moparmike07 will become famous soon enough
^^^^^^^^^ exactly what he said i was going to say same thing
2007 dodge ram 1500 quad cab 4x4 5 percent tint all around 35 percent windshield, ported tb, diablo sport, arh headers, magnaflow dual exhaust, magnaflow y pipe, krc210x cam,nitrous,CNC ported head. 4.56 motive
Old 04-24-2011, 05:26 PM
RamRod07's Avatar
Rep:15
Thanks guys that helps a lot. This is probably a dumb question but whats the tstat you guys mentioned?
