AC stops blowing at certain RPMs - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > LD RAM - General Discussion
LD RAM - General Discussion RAM 1500 General Chat. Please post your tech questions in the HELP Zone!
Old 04-15-2011, 08:13 AM
ARMedNBangin's Avatar
ARMedNBangin ARMedNBangin is offline
Vehicle: 1999 Dodge Ram 4x4
Trim Level: Laramie slt
Color: Black/Grey
Rep:16
ARMedNBangin is on a distinguished road
Default AC stops blowing at certain RPMs
As said in the title, sometimes the AC stops blowing out of the vents when I hit a certain rpm. At first I thought it was just between 60-65 mph, but I goosed the gas in lower gears and noticed it was doing the same thing at other speeds. You can still hear the blower doing it's thing, but when it hits that magic rpm number, the air starts blowing out somewhere else...(haven't really tried to figure out where it was going--other vents, just up in the dash, etc.) Then after it shifts gears and the rpms change, or if you let up off the gas, the air will start blowing back outta the vents I selected.
Is this a common problem? Something to be worried about?? Easy fix?
Ideas, suggestions:
Aaron Roy Matherne--99 Ram 1500 4x4 5.9L Laramie
I got 99 problems but my truck ain't one.
Old 04-15-2011, 05:59 PM
letsjet's Avatar
letsjet letsjet is offline
Vehicle: 2014 Ram 1500 Express 5.7L 4x4
Trim Level: EXPRESS
Color: FLAME RED
Rep:45
letsjet is on a distinguished road
I had the exact same problem on a 1999 intense blue 1500 4 x 2 5.7 auto. The dealer could'nt fix it, only seemed to do it when the outside air temperature was really, really hot. Could be a loose vacuum line to the vent. Good luck, it's a pisser to lose the a/c if it's only for a minute or two.
2014 Ram 1500 "Sport"Express 5.7L Quad Cab 4 X 4 Flame Red
2010 Dodge Challenger R/T Furious Fuchsia 6 speed
2016 Jeep Rubicon 4 X 4 Firecracker Red
2017 Z51 Corvette Stingray
Old 04-16-2011, 09:44 PM
ArmyofOne's Avatar
Some Assembly Required
Vehicle: 2015 Ram 1500 CC 4x4
Color: Blue Streak Metallic
Rep:1260
Are you sure the air stops blowing completely? Because I know your truck (and most cars nowadays) have whats called a WOT (Wide Open Throttle) cutoff switch, when your accelerator is pushed passed (in most vehicles) 50%, the ac compressor shuts down to allow extra power, it then kicks back on below 50% throttle. During the off time, the temperature of the air coming from the vents changes to ambient. It can feel sometimes like the air has stopped blowing but it hasnt. Could this be your issue?
COMBAT WOUNDED VETERAN
-2015 Ram 1500 Laramie Crew Cab 4x4. Lifted, Modded, Attitude.
2002 Lexus ES300. My Daily.
2014 Civic EX. Wifey
2008 Corvette Pace Car Convertible. #325/500
Old 04-17-2011, 10:14 AM
Color: Black/Grey
Rep:16
You can still hear the blower spinning...but when you put your hands to the vents that blow on your face, NOTHING comes out...not even hot air. As soon as the gears shift, or I let off the gas just a hair, the blower's noise does not stop or deviate any, but the cold air immediately returns to blowing out of those vents again. It's as though a valve of sorts is opening allowing the air to move elsewhere. Perhaps my WOT is the problem. If it's supposed to be working like it is, then that's cool. But if it's something that's wrong and can be fixed, I'd rather get it taken care of. Summer days here in South Louisiana can be brutal.
If it's a common occurance, or something that is SUPPOSED to be happening, I sure wish other people with similar stories would chime in and set me straight.
A vaccuum line? Somewhere down the line, i've heard of this problem. I don't know where I heard it from, but as I was making this initial post, that was in the back of my head--remembering a similar problem happening to a friend or colleague in the recent past and it ended up being a loose vaccuum line.
Old 04-18-2011, 11:38 AM
ArmyofOne's Avatar
Rep:1260
Ok, so you either have a vacuum line off/broken or a vacuum leak elsewhere. The air is not supposed to stop coming out, just change temps.
If your motor is still going with no air from the vents, that air is going somewhere. Vacuum leak is the next logical step.
Old 04-18-2011, 11:49 AM
Resident Technician
Rep:1915
It's a bad vacuum check valve in the line leading to the interior of the truck.
Old 04-26-2011, 05:23 PM
xlstreetglide xlstreetglide is offline
Trim Level: SLE
Color: Grey
xlstreetglide is on a distinguished road
So I've replaced both check valves now my air is coming out the defrost vents. What gives. Did I put them in wrong?
Old 04-26-2011, 06:27 PM
Color: Black/Grey
Rep:16
Randy, where exactly is it located?
And on a scale from 1-10, how difficult of a fix will that be? I can change an alternator, change brake pads, etc, but I'm not completely mechanically inclined.
Cost of replacement valve??
Old 04-26-2011, 08:11 PM
Trim Level: SLE
Color: Grey
Passenger side firewall and by intake.
1 being easy
4.00ea from dealer. Local auto parts don't carry them. Part#4549209
Old 04-28-2011, 11:03 AM
Color: Black/Grey
Rep:16
aw hell, you've just boosted my confidence. Easy, $4 fix. That's what I'm talking about. I've gotta get it from a local Dodge dealer? Do you know of an online source for purchasing the part?
Vibration around 2500 rpms lucidanomaly Newbie Checkin! 15 11-28-2016 05:05 PM
ac stops blowing at higher rpm???? dirty97ram Heating & Cooling 18 04-10-2014 01:25 PM
1999 5.9L (gas) - No power under 3500 rpm's IntenseDakota LD RAM - General Discussion 1 04-01-2011 04:03 PM
Gas fill up and engine light then higher rpm's jayhkr LD RAM - General Discussion 6 12-18-2010 12:10 AM
Pro comp levelling kit and bump stops wetcoast Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 6 06-15-2010 01:54 AM
