Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram – 1994 to 2001 Dodge Ram Trucks > Powertrain > 5.9L V8 Specific Topics
Place your Ad Here!
Old 04-15-2011, 06:05 PM
timmytard timmytard is offline
Vehicle: 1998 dodge ram 2500
Color: dented white
timmytard is on a distinguished road
Default tough one to figure out
Not sure if this is where this post goes, if not could someone direct me.
Ok. I have a problem, it might be three diff problems, but I'm hopin' it is just one.
I bought this truck, a 1998 ram 2500, 5.9 Magnum gas engine about 4 months ago, when I bought it the guy said that the check engine light and abs light had come on periodically ever since he bought it, but he couldn't figure out why, nor could the dealership & that he just had it serviced @.
I have a pic of this too.
The dealership charged him $200 (I have the receipt) On the receipt, it is noted that: after installing the sensor, a new ABS FA ULT code was tripped. Cust to return. I'll take a pic.
Then I did this http://www.ramforumz.com/showthread.php?t=65683
Then my AC/motor died & snapped the belt, I bought a used belt from an auto wrecker & they threw in the ac/motor & all the hoses one, but the hoses didn't line up so I put it in but didn't hook up the hoses or power.
as outlined here. http://www.ramforumz.com/showthread.php?t=67221
Every thing seemed to work all right.
My mom just passed away, the bank is trying to foreclose & my power's cut off. So I've been sitting in my truck using my mom's laptop, but lately it has drained the battery a couple times, to the point I needed a jump.
Not sure if the power thing is a contributor or not?
Now the latest problem, my battery died with me sitting in it, I couldn't start it so I left it on the side of the road. Came back the next day to jump it.
It started after a couple times but wouldn't stay running without my foot constantly on the gas, & it was making what sounded to me like a suction noise, like a hose came off. Checked, all good.
Tried to get it home but I pretty much had to do a neutral drop from a stopped position, just so it wouldn't die. No luck it died.
How it died was kinda weird too. It didn't bog out or sputter, it would just stop. Like instantly my foot wasn't on the gas. I thought it was seconds away from seizing. I don't really know that much about engines.
after checking again I noticed that my serpentine was so tight it felt solid, no play what so ever.
So I pushed the tensioner back a bit & it almost stayed there, so I wiggled it back & forth a few times & voila, I had fixed it.
But my neighbor says there is no way in the world that the belt being to tense would slow down my 360ci (5.9L), he thinks there has to be some thing else wrong with it & that the belt being to tight was just helping it die.
Any one had anything similar happen to them, or have any idea what is happening to mine.
Sorry for the long winded post, just wasn't sure if any of these things were related so I figured the more details the better.
I will post the pics as soon as I get home.
Thanks
TT
Old 04-15-2011, 10:00 PM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
Hi and sorry to hear of the numerous problems plaguing you in life and with the truck. I hope one of our great tech’s will chime in and point you in a direction with the engine. In the mean time you will be in my thoughts.
Old 04-16-2011, 02:59 AM
jgshannon jgshannon is offline
Vehicle: 2005 Dodge Ram 1500
jgshannon is on a distinguished road
I know whenever my dad's Ram dies or my brother runs the truck out of gas it tends to do sporadic things. One of the main things is it sucks gas up like crazy, about 5mpg. He has to reset the computer every time it happens. It might just be something going on with your computer as well, cars do crazy things when their batteries die. I would take the battery cables off, wait a few seconds, touch the two together (which will drain all power left in the system, thus resetting the computer) and then reattach them and see if that might fix it.
Old 04-17-2011, 03:54 AM
Color: dented white
Well that sounds like a pretty easy thing to try, it's not going to screw any thing else up though is it?
Old 04-17-2011, 08:45 AM
sdram03's Avatar
sdram03 sdram03 is offline
Vehicle: 2014 RAM 3500 Big Horn
Color: Maximum Steel
Rep:52
sdram03 will become famous soon enough
nope. i've used that process before on a few vehicles and sometimes, it can work wonders... for a lil while.
good luck and press on!
if you're gonna go, go with a smile!
2014 RAM 3500 Big Horn CTD CC 4wd in Max Steel
Old 04-19-2011, 03:46 PM
Color: dented white
Ok, I did it & so far no problems.
Here is a link to a pic of what I hope I don't see any more.
Trust me the parking brake isn't on.
http://www.badongo.com/pic/12863567
5.2/5.9 Misfire TSB 18-48-98 RamTech Dodge Ram Knowledge Base 3 06-22-2014 07:45 AM
Hello, Ram Tough Ram Tough Newbie Checkin! 14 04-24-2011 07:24 PM
90's lightning trying to be tough veilofmaya7 2010 Dodge Ram Forum 1 01-22-2011 12:51 AM
Fender flares not so Ram Tough. Invisible bras/protection Quiet Lunatic 5.7L (345 cu in) HEMI V8 Specific Topics 6 01-14-2011 12:03 PM
How to figure out gear ratio ramit04 Custom Dodge Ram Performance Mods - Engine - 4.7 Liter V8 7 11-13-2009 05:36 PM
