Old 04-26-2011, 09:22 PM
Krpto1973's Avatar
Krpto1973 Krpto1973 is offline
Vehicle: 2011 Dodge Ram 2500 4x4
Trim Level: Power Wagon
Color: Blue
Rep:71
Krpto1973 will become famous soon enough
After my install, I had the thought that I could go to a machine shop and cut out some braces that would run from the back of the mounts of my n-fabs, that would run over to the frame and help create that support and stiffness I wanted from the nerfbars, but then I realized that would screw up the whole body mounting systems that allows it to flex on the frame. So that Idea went out the window.
-2011 Dodge Ram 2500 4x4 Power Wagon
-2006 Suzki GSX-R 750, 2004 Triton Tr-19x
Old 04-26-2011, 09:23 PM
Rough 01 Rough 01 is offline
Vehicle: 2011 Ram 1500 Sport
Trim Level: Sport Quad Cab
Rep:67
Rough 01 will become famous soon enough
I'll chime in with my $.02 here. I think that steps and nerf bars are two completely different things. Steps should be for access to the truck (primary) while nerf bars should be there for protections (primary). It's almost impossible to get both because steps need to be low in order for them to function while nerf bars need to be up close to the body and mounted to the frame (if possible). If you do both then you get the worst of both worlds.
I used to off road jeeps all the time and built a few up from scratch. I'm very familiar with how they work and what they are used for. I chose the N-fab steps (that look like nerf bars) because I liked the look and the hopes for less snow/mud catching in them. I have no expectation that they will protect my truck. In fact, I expect them to cause more damage to my truck if I get into an off roading glitch.
This is because they are low to the ground and could damamge my rockers because they are only bolted to the sheet metal (like 99% of the other steps out there... to include OEM).
I would say that building a hybrid of the 2 doesn't make much sense because they wouldn't be good at either job.
(off my soap box)....
Old 04-26-2011, 09:31 PM
Rkeytek's Avatar
Rkeytek Rkeytek is offline
Vehicle: 2011 ram 1500
Rep:210
Rkeytek has a spectacular aura aboutRkeytek has a spectacular aura aboutRkeytek has a spectacular aura about
I think any frame mounting should be to the body mounts, and only mount to the frame if there is no body connection (as you said to allow that built in flex)
Krpto1973's Avatar
Color: Blue
Rep:71
But I want what I want, and I want it now! I'm gonna go cry.
Old 04-26-2011, 09:35 PM
Rkeytek's Avatar
Rep:210
Rock "skis" or sliders for jeeps are mostly mounted to the rocker or sheet metal like you said as well as all jeep "body armor"
But the mounting spreads the load over a greater area and of course are constructed from thicker material of course.
Sorry to thread Jack...I will continue this discussion in my section
Old 04-30-2011, 04:00 PM
leapaldt87 leapaldt87 is offline
Vehicle: 2011 dodge ram
Trim Level: sport
Color: mineral grey
leapaldt87 is on a distinguished road
steps and nerf bars are the same thing... are you sure you aren't thinking of rock sliders, or sport bars? because a nerf bar is for stepping up into the vehicle... hence the black rubber non slip pad on top of them or a perferated non slip metal step like the n fabs, a sport bar (rock slider) what ever you choose to call them is strictly for looks and to protect the bottom of the rocker panels... which is why they have no grip at all on them and they hug the bottom of the rocker panels. just wanted to clear that up.
Old 04-30-2011, 04:20 PM
Trim Level: sport
Color: mineral grey
rough01 are yours the wheel to wheel length ones?
Old 04-30-2011, 06:15 PM
Rep:67
Mine are not. I didn't like the look of that style personally and I like the way it looks by ending with the cab.
Old 05-11-2011, 10:47 PM
TxPride911 TxPride911 is offline
Rep:27
TxPride911 is on a distinguished road
Sorry to hear about the difficulty of installation. I was going to purchase the N-Fabs as I think they look great on the truck but I'm not trying to go through the fuss.
Old 05-11-2011, 10:59 PM
Firemut30 Firemut30 is offline
Vehicle: 2011 Ram 1500 Sport 4x4
Firemut30 is on a distinguished road
I got the wheel to wheel, if I figure out this new laptop I will post pics. And yes, they were alittle extra work to put on but it was what I liked.
New Nerf Bars, Running Boards, Step Rails datrep Custom Dodge Ram Exterior Modifications - Body Mods - Body Kits 29 07-28-2013 08:56 PM
Iron Cross Plus Step Nerf Bars On My Ram wolfman10 Custom Dodge Ram Exterior Modifications - Body Mods - Body Kits 15 04-19-2011 12:13 AM
Step Rail (nerf bar) Dilemma moparornocar72 2010 Dodge Ram Forum 23 02-25-2011 04:50 PM
Nerf Bars without step pads ttontis Custom Dodge Ram Exterior Modifications - Body Mods - Body Kits 5 05-30-2010 11:06 PM
