Old 04-16-2011, 02:18 PM
roundtownram roundtownram is offline
Vehicle: 2003 ram 1500
Color: burgandy
roundtownram is on a distinguished road
Default leaking oil from front axle
i have a 2003 ram 1500 4x4 and leaking gear oil where the cv shaft slips into the front axle. is this hard to fix? everywhere says it is a dealer part. what is involved in fixing this problem?
Old 04-16-2011, 09:49 PM
ArmyofOne's Avatar
US Army Retired
Color: Blue Streak Metallic
Rep:1195
Its as simple (or not) as pulling the CV shaft, and changing the input seal on the Differential. Its not a hard job, if you know what you are doing. Napa should carry the part, otherwise the dealer would be the only place, but a seal should only be about $20 max. It is a steel encased rubber seal with a spring compressor in it, so you will have to pry the old one out and beat the new one in with a rubber mallet.
US ARMY-RETIRED
2015 Ram 1500 Laramie 4x4 Crew in Blue Streak Metallic Pearlcoat-Mopar spray-in Liner, Mopar Mud Flaps, 20% tint, Mopar Side Steps, Best-Top Tri-Fold Bed Cover, DZ Tailgate assist.
2002 Ford Focus ZTW Wagon-loaded, tinted and tunes. 183k miles and counting...
Old 04-29-2011, 05:04 AM
lucky262's Avatar
lucky262 lucky262 is offline
Vehicle: 2003 Dodge Ram 4X4 6"lift
lucky262 is on a distinguished road
Its not a hard fix. pull the cv axle, then pull the seal. I just replaced both cv axles and both seals they are like 10 bucks at Oriellys. Hopefully the guy at the counter is smarter and more mechanically inclined than the one I ran into.
Front Axle Replacement Leadchunker Dodge Ram 4x4 - Offroad Discussion 4 01-21-2011 10:23 PM
Square Box that come out of Front axle leaking!!!? sixwheeler 5.9L V8 Specific Topics 2 11-08-2010 09:28 PM
front axle 99 ram slt Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 1 01-14-2010 06:40 PM
Front axle leaking after u-joint change LittleMoe Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 5 11-15-2009 09:05 AM
Front Axle swap and other info Crazy Canadian Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 4 06-12-2009 06:05 AM
