Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 2nd Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 04-16-2011, 04:02 PM
mcasdorph mcasdorph is offline
Vehicle: 1996 Ram 1500 Club Cab 4x4
mcasdorph is on a distinguished road
Default A/C Compressor Clicking on and off, Refrigerant Question
I read around that it could be low, my question is what is the capacity of refrigerant that it holds? (1996 Ram 1500 5.9L V8)
I know it takes R-134a, is there anything special I need to recharge it? or can a just buy some cans of R-134a at advance?
Old 04-16-2011, 04:31 PM
RansRAM's Avatar
RansRAM RansRAM is offline
Addicted to the Z
Color: PX8 Black
Rep:2471
Smile
I believe it's around 30oz's. If the compressor is cycling it is likely low so no need for specalized equipment. It sounds like you should be able to buy a couple of cans or R-134a and top it up yourself. Only add it to the low side of the system. Also be careful not to overcharge it. Just add the freon until the compressor stops cycling and the large low pressure line coming off the compressor starts to get cold. Be careful and follow all the instructions that come with the cans. Please remember that I am not a mechanic however I have worked installing aftermarket A/C systems. If this fails to correct the problem you should take it to a professional. Good luck and let us know how it goes.
Old 04-16-2011, 04:44 PM
tmerritt530's Avatar
tmerritt530 tmerritt530 is offline
Vehicle: 2004 Ram 1500 4.7L "H/O"
Color: Graphite Metallic
Rep:91
tmerritt530 will become famous soon enough
The correct sharge is 32 ounces of R-134a
2004 SLT RCSB 4.7L | 3.92 | OEM Off-Road wheels | Goodyear SilentArmor 285/70R17's | dumped magnaflow | H/O cams | H/O cyl heads | 10" Rockford Fosgate P1
Old 08-11-2011, 12:12 AM
01DodgeRam1500 01DodgeRam1500 is offline
Vehicle: 2001 Dodge Ram
01DodgeRam1500 is on a distinguished road
i have the same problem. I can here a hissing sound when the compressor turns on inside the truck, and when the compressor cycles off again a few seconds later the hissing goes away.. will the hissing inside the truck go away if i add refrigerant?
