Old 04-16-2011, 07:15 PM
Ram Tough's Avatar
Ram Tough Ram Tough is offline
Vehicle: 1999 Dodge Ram 1500 Sport 4x4
Color: Primer Gray
Ram Tough is on a distinguished road
Default 46re trans
I have a 1999 Ram 1500 4x4 with a 46re trans. The problem I'm having is the trans wants to go forward in all gears P-R-N-D-2-1, I don;t no where to look for this. I changed the solenoids and gov. pressure switch while pan was off I checked everything out including the manual valve to make sure I put it back together right cause I had to remove the valve body to replace the solenoids and everything looked good. I don't know whats causing the trans to want to go forward in all gears...... Any help will be greatly appreciated Thank you....
Old 04-16-2011, 10:27 PM
ramvan2500's Avatar
Trim Level: SLT - 2500
Rep:128
I have the 46RH... Besides the point though lol...
You might want to take that to a specialist because that doesn't sound good. But if you know how and are willing I recommend you have the transmission rebuilt cause it just doesn't sound good.
Old 04-17-2011, 08:26 PM
Ram Tough's Avatar
Color: Primer Gray
Default 46re trans
Well I just ordered a complete overdrive unit and I'm going to change the unit out because I believe the overdrive unit is the root of my problem. My son and I rebuilt the transmission but were not able to rebuild the overdrive because of the hefty spring that needs to be compressed in order to replace the fiber and steel plates as well as clean the unit. I'm tired of messing with this trans its time to geterdone.....
1998 trans issue embry1123 5.2L V8 Specific Topics 3 04-17-2011 06:20 PM
Trans rebuild 94ram1500 5.2L V8 Specific Topics 4 04-07-2011 09:49 PM
$3,500+ in trans repairs,etc still no fix HELP! rcs4787 5.2L V8 Specific Topics 5 11-17-2010 01:48 PM
Possibly need new trans... IntenseDakota 5.9L V8 Specific Topics 5 09-27-2010 07:48 AM
Trans wont shift always in second donjuan7z Cummins Diesel Specific Topics 2 09-18-2009 10:44 PM
