Transmission Shifting Problem - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > 5.2L V8 Specific Topics
Old 04-16-2011, 08:11 PM
monster406s10 monster406s10 is offline
Vehicle: 2001 Dodge Ram
monster406s10 is on a distinguished road
Default Transmission Shifting Problem
I have a 2001 Ram 2wd standard cab. I've put over 110,000 miles on it and the transmission has shifted like new sense i bought it but it is starting to develop a shifting problem. Usually when you take off easy it will shift around 1300 - 1500 rpm's. Lately when you take off easy it will rev up to about 2,000 - 2,500 rpms. It still shifts smooth but i know this isn't normal. I'm assuming there is a sensor or two that tell the transmission when to shift so maybe one of those is screwing up? Any advice would be great. Thanks.
Old 04-16-2011, 08:53 PM
stuckinmud's Avatar
stuckinmud stuckinmud is offline
Vehicle: 1997 dodge ram 1500
Rep:14
stuckinmud is on a distinguished road
theres a cable that runs from the throttle body linkage to the transmission its called a kickdown or throttle valve cable , it could be sticking a little causing the late shift
Old 04-23-2011, 06:12 AM
RAMING IT's Avatar
RAMING IT RAMING IT is offline
Vehicle: 2002 DODGE RAM
Trim Level: QC SLT 2WD
Color: Almond Pearl, Blacked Out
Rep:65
RAMING IT will become famous soon enough
Also look underneath your truck on your tranny were that kickdown cables connects from your tb, theres a spring that attaches to it (cable and tranny) it gets loose and looses tension over the years. Tighten it up or replace it..thats only one option.
Heavy A$$ truck w/ ported stock heads, intake / heads gasket matched, keg mod, iat mod, cks mod, 2 tone vinyl wrap, blacked out trim, (pcm junkyard mod)
Transmission Problem 07 Hemi 07Ram 5.7L V8 Specific Topics 14 03-14-2013 06:45 PM
1996 ram 1500 transmission problem chadartfunkal 5.2L V8 Specific Topics 3 11-15-2012 09:33 PM
2001 Ram1500 5.2 L Transmission shifting problems Mic Shaw 5.2L V8 Specific Topics 12 06-13-2011 08:29 AM
Tranny Shifting Problem an4rchy Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 7 03-15-2011 12:07 AM
'01 Dodge Ram 4wd shifting problem CloneSaw Cummins Diesel Specific Topics 2 02-10-2011 01:25 PM
