Old 04-16-2011, 10:45 PM
Ryank's Avatar
Ryank Ryank is offline
Vehicle: 2009 Dodge Ram
Rep:199
Default Some help on coil spring installation?
Alright so this summer i'm getting some 3" lift coil springs, was going to get spacers but springs are only like 50 bucks more, and new shocks. But anyways in my Haynes manual it says to pretty much dissconect the whole axle from the truck to take out the springs, is the correct, or is there a better way to do It? also with the 3" coils do you think i could fit 35's, i'm pretty sure i could.
thanks.
Old 04-17-2011, 01:43 PM
Ryank's Avatar
Rep:199
Anyone?
morning bump
Old 04-17-2011, 02:34 PM
I'm really not sure how this is done. I haven't torn apart the front of your generation truck. 35's with 3" coils will be tight. I have a 4" lift & 35's and I have just enough room. Of course, the body and suspension architecture is different on my truck.
Good luck!
Old 04-17-2011, 05:02 PM
Ryank's Avatar
Rep:199
Thanks maddog! I'm pretty positive they will fit, if not i can always get like a 1" body lift, but i think it'll fit and i like the look really stuffed fender wells!!
Old 04-17-2011, 09:41 PM
Vehicle: 2005 Dodge Ram 2500
Color: Mineral Gray
Rep:177
When I did spacers on the 2500 I had to take off the sway bar and the track bar. I ended up putting a bottle jack between the axle and frame to push it down enough to get the spring and spacer back in.
A spring compressor could help but be really careful
new coil spring ride skyblue Suspension 2 01-31-2011 02:40 PM
Coil spring question. Please answer fast!! BLACK07 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 2 07-06-2010 11:22 PM
Coil spring dimensions cumminsburban Suspension 0 06-15-2010 09:49 PM
Leaf nd Coil spring spacers 20ramquad04 Dodge Ram Wheels And Tires 3 03-31-2010 11:24 PM
Coil spring spacers vs torsion keys ramjam02 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 3 01-25-2010 03:26 AM
