tonneaucovered.com
Old 10-04-2011, 12:51 PM
mr.lopar's Avatar
mr.lopar mr.lopar is offline
Vehicle: 1999 dodge ram 1500
Trim Level: baja/prerunner
Rep:192
you can do that, but youll have to find a shop that can weld aluminum, and before you do that, make sure to do the kegger mod 1st
Old 10-04-2011, 03:31 PM
Gen1dak Gen1dak is offline
Vehicle: 1990 RamCharger
Rep:93
Originally Posted by Paul89 View Post
Hughes intake is designed by Hughes Engines and is manufactured by Edelbrock and Edelbrock version does look the same. Have not seen them side by side but I bet they’re the same. The link you have from Summit is the wrong intake for a MFI. Also you will need I believe the EGR version for a 97 plus parts to finish the setup if you decide to go this route. Hughes is a complete setup for the engine. Personally I believe in simplicity so Hughes is the way I’m going due to a complete setup and how professional the staff is there. Cost is always the bottom line for everyone and saving a couple of bills are worth doing more research other then Summit.
OBD II did away with EGR in 1996. The Hughes MPI intake is an Edelbrock Performer RPM intake for carburetor. These intakes have bosses in the runners for nitrous oxide injectors. They're ideally placed, so Hughes uses them for the Magnum fuel injectors. Some of the work they did involved placement of the injectors for best power, as depth and angle of the injector tips can change the numbers a bit. A wet manifold is gonna flow dry air that much better when, though optimized to avoid fuel dropout, it's only flowing air. It's a great adaptation of the manifold. The cost, while steep, isn't unjustified. You're buying what is basically a low numbers run, customized intake. There's machining involved, and extra parts. I haven't been able to get one, but I want it. Hats off to Hughes for doing this.
3.9/5.2/5.9 Intake Removal & Installation RamTech Dodge Ram Knowledge Base 7 05-13-2016 12:55 AM
Kegger MOD DIY wermbang Dodge Ram Knowledge Base 8 09-09-2012 02:05 PM
Keggar Mod wermbang Dodge Ram Knowledge Base 1 04-05-2011 02:16 AM
Intake Manifold Ram50Man Dodge Ram General Discussion 2 01-19-2011 09:09 AM
Intake manifold soco native Custom Dodge Ram Performance Mods - Engine - 5.9 Liter V8 13 02-06-2010 08:52 PM
