Old 04-17-2011, 02:55 PM
jt10hemi jt10hemi is offline
Vehicle: 2010 Ram 1500
Color: mineral grey
Rep:23
jt10hemi is on a distinguished road
Default Pioneer AVH P3200BT to PAC harness?
I just finished all the connections for the wiring harness, but have 3 wires left untouched. Is this normal for using the PAC C2R-CHY4 harness?
I did not use the SWC module yet.
1) So what I have is the yellow/black (mute wire) according to the pioneer diagram this is unused.
2) from the PAC 11 pin conn. I have the violet/white wire VSS output (pulse).
(not sure what that is for).
3) from the 22 pin radio wire harness I have the blue antenna on input.
(didn't see where this needed to be used)
Everything matched up and when plug in all worked well on the H/U.
just looking for confirmation I didn't screw something up.
Thanks for your help!
Old 04-18-2011, 01:03 PM
restes restes is offline
Trim Level: Crew Cab
Rep:30
restes is on a distinguished road
I'm about to install the same setup. Which factory unit did you replace?
Old 04-18-2011, 10:48 PM
I push the skinny pedal
Rep:3277
I picked up that same harness, but didn't install it as my install didn't require a can-bus adapter since I was installing all new amps and speakers + wiring. When I was mapping out using the harness though, the mute line hooked up to the factory orange or brown (I think) mute wire, for when your bluetooth actives; the blue was unused on mine as well since it's a non-powered antnnae; and I too had no idea what that VSS line was for.
Kurtis
Old 04-18-2011, 11:18 PM
Color: mineral grey
Rep:23
RESTES,
I had the basic RES head unit.
A little advice if you are installing the same unit trim the top plastic area of the trim first. The plastic is folded over and I only trimmed off the extra plastic from the fold (if that makes sense). and you will need to bend the metal tabs on the bottom of the metal bracket.
Try that first and it may save time and unwanted trimming of the bottom area of the plastic bracket.
I posted pictures in another post on here. not sure how to post the link sorry.
Old 04-18-2011, 11:34 PM
Color: mineral grey
Rep:23
Originally Posted by jt10hemi View Post
RESTES,
Here is a picture, hope it works.
Old 04-18-2011, 11:41 PM
Color: mineral grey
Rep:23
Found out what the VSS output is for....
(GPS to Speed pulse interface / Vehicle speed signal (VSS) output) so since I am not using a GPS I am guessing that I do not need to use this wire.
Old 04-19-2011, 09:46 PM
Rep:30
I think that makes sense but the pictures helps
Thanks
Old 04-22-2011, 11:31 PM
Skillets's Avatar
Skillets Skillets is offline
Vehicle: 2011 Dodge 1500 Big Horn Hemi
Color: Dark Cherry Red
Rep:12
Skillets is on a distinguished road
jt10hemi where did you get the installation dash bezel/kit? for the double din.
Old 04-23-2011, 10:31 PM
Rep:30
Looks like the SCOSCHE CAR CR1291B Double DIN Kit for 2007 Dodge
Part No: 160337
I got mine from Petra.
Old 04-25-2011, 08:37 PM
Color: mineral grey
Rep:23
Got the kit from a local audio store, it is a Metra model 95-6511.
trim kit for pioneer AVH P3200BT jt10hemi Custom Dodge Ram Interior Modifications - Custom Audio / Video 5 02-15-2013 09:33 AM
