Gauge cluster going crazy losing all gauges no wipers,horns or brake lights odometer reads no bus - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Electrical
Old 04-17-2011, 08:34 PM
newlife61 newlife61 is offline
Vehicle: 2003 dodge ram 1500
Trim Level: sl
newlife61 is on a distinguished road
Default Gauge cluster going crazy losing all gauges no wipers,horns or brake lights odometer reads no bus
the cluster has every light on, wipers stop working, horn is inop, no brake lights , i lose the over head temp and fuel mileage, odometer reads "NO BUS" i already changed the cluster didnt work , i changed the electrical part of ignition switch still didnt help, checked all connections everywhere all good, the problem was interminent but now every time i start the truck its good for about 5 minutes then the cluster goes crazy anyone have any ideas what else it could be?
Old 04-17-2011, 08:37 PM
Test your battery and all your main power connections at the battery, starter, ground and the computer. One other possibility is that your PCM is going bad.
Old 04-17-2011, 08:50 PM
brad12kx's Avatar
brad12kx brad12kx is offline
Vehicle: 2010 Ram 1500 QC
Rep:2581
Here is an exert from the 2003 service manual -
PRELIMINARY DIAGNOSIS
WARNING: ON VEHICLES EQUIPPED WITH AIRBAGS,
DISABLE THE SUPPLEMENTAL RESTRAINT
SYSTEM BEFORE ATTEMPTING ANY STEERING
WHEEL, STEERING COLUMN, DRIVER AIRBAG,
PASSENGER AIRBAG, SEAT BELT TENSIONER,
SIDE CURTAIN AIRBAG, OR INSTRUMENT PANEL
COMPONENT DIAGNOSIS OR SERVICE. DISCONNECT
AND ISOLATE THE BATTERY NEGATIVE
(GROUND) CABLE, THEN WAIT TWO MINUTES FOR
THE SYSTEM CAPACITOR TO DISCHARGE BEFORE
PERFORMING FURTHER DIAGNOSIS OR SERVICE.
THIS IS THE ONLY SURE WAY TO DISABLE THE
SUPPLEMENTAL RESTRAINT SYSTEM. FAILURE TO
TAKE THE PROPER PRECAUTIONS COULD
RESULT IN ACCIDENTAL AIRBAG DEPLOYMENT
AND POSSIBLE PERSONAL INJURY.
(1) Check the fused B(+) fuse (Fuse 28 - 10
ampere) in the Integrated Power Module (IPM). If
OK, go to Step 2. If not OK, repair the shorted circuit
or component as required and replace the faulty fuse.
(2) Check for battery voltage at the fused B(+) fuse
(Fuse 28 - 10 ampere) in the IPM. If OK, go to Step
3. If not OK, repair the open fused B(+) circuit
between the IPM and the battery as required.
(3) Disconnect and isolate the battery negative
cable. Remove the instrument cluster. Reconnect the
battery negative cable. Check for battery voltage at
the fused B(+) circuit cavity of the instrument panel
wire harness connector (Connector C1) for the instrument
cluster. If OK, go to Step 4. If not OK, repair
the open fused B(+) circuit between the instrument
cluster and the IPM as required.
(4) Check for continuity between the signal ground
circuit cavity of the instrument panel wire harness
connector (Connector C1) for the instrument cluster
and a good ground. There should be continuity. If
OK, refer to ACTUATOR TEST. If not OK, repair the
open ground circuit to ground (G202) as required.
Hope this helps.
brad
Interested in one of my mods?
Old 09-26-2012, 12:27 PM
NASATrucker NASATrucker is offline
Vehicle: 2000 Dodge Ram Sport
NASATrucker is on a distinguished road
Default My "NO BUS" experience is Airbag Control Module
Although this looks like an older thread, let me add my recent experience:
Out of the blue, I got the "NO BUS" error, with all instrument clusters not working. Everything else seemed to work fine and the truck still ran fine.
I went thru the service manual procedure, at least as much as I could (sorry, I don't have a DBIII scanner). Took it to the local Dodge dealer and they reprogrammed the PCM, and other modules. During this, they said it **appeared** the AirBag Control Module was at fault, but after re-programming it, thie issue fixed itself.....they ran it/started it several times and no errors. I just picked it up this morning and it all still appears normal. The labor cost was $150 (1.5 hours), but WELL worth it to check something I could not w/o a $9000 scanner (oscilloscope). From what I found, the data bus is piped thru many difference modules and any one could be the culprit. Damned cars/trucks with everything computerized is a service nightmare after a few years - in my case the truck is a 2000 WITH ONLY 54K miles. Good luck to anyone with "NO BUS"......
Old 09-26-2012, 10:29 PM
Screwbs's Avatar
Screwbs Screwbs is offline
Vehicle: 2002 Dodge Ram 1500 SLT
Screwbs is on a distinguished road
I would side with the Front control module attached to the fuse box. A lot of the functions you mentioned are controlled by this module. Could need a reprogram or new system.
Gauge cluster going crazy losing all gauges no wipers,horns or brake lights odometer reads no bus newlife61 Newbie Checkin! 14 05-26-2011 12:21 AM
Parttime Speedo Dragonslayer Electrical 8 09-08-2010 10:43 PM
2003 Dodge Ram 1500, No Gauge Cluster lights and No Start Tonatom Electrical 24 06-15-2010 05:54 PM
Third brake light causing the brake lights to stay on? Due Electrical 7 05-19-2010 02:33 PM
Gauge Cluster Light Is Not Working but radio lights are Goodfellas Electrical 2 08-21-2009 06:56 PM
