Old 04-18-2011, 01:35 AM
country livin country livin is offline
Vehicle: 1998 dodge ram 1500 4x4
country livin is on a distinguished road
Default 46re 4x4 TRANS problem HELP ME PLEASE!!!
i have a 1998 dodge ram 1500 4x4 with 100 somthing thousand miles and theres a shifting problem when ever i take off from a start it wont shift into second unless i let up off the gas then it will shift and when its in over drive with feels like its jerking or slipping and im pretty sure i got to replace the whole thing but maybe just a sensor so please let me know what you thing oh and one more thing it wont start in park just neutral and this all happend in one day not gradually..
thanks
Old 04-18-2011, 11:52 AM
ramvan2500's Avatar
Trim Level: SLT - 2500
Rep:128
The not allowing you to start in Park is due to the neutral safety switch. The not allowing you to shift may be related but can't say for sure. Check into having the valve body replaced or rebuilt. I have the 46RH which doesn't have the electronic governor on it yours does have electronic governor hence RE.
Old 04-18-2011, 08:15 PM
Ram Tough's Avatar
Ram Tough Ram Tough is offline
Vehicle: 1999 Dodge Ram 1500 Sport 4x4
Color: Primer Gray
Ram Tough is on a distinguished road
Default 46re trans trouble
have you checked for trouble codes for instance dtc code p1765 which is a dodge code for (transmission 12 volt supply relay control unit) which is the solenoids / governor harness. To change the solenoids harness comes with new solenoids overdrive and TCC (TORQUE CONVERTER CLUTCH) But the valve body has to be removed because of the thru case connector. while changing solenoids also change the the gov pressure switch and the governor pressure solenoid. The governor has to be removed to remove the O/D--TCC
SOLENOIDS good luck.....
46re trans Ram Tough 5.2L V8 Specific Topics 2 04-17-2011 08:26 PM
trans burnt fluid problem pirayaman 5.9L V8 Specific Topics 4 03-30-2011 08:20 AM
Trans problem 09m109r 2009 Dodge Ram Forum 7 02-02-2011 07:55 PM
$3,500+ in trans repairs,etc still no fix HELP! rcs4787 5.2L V8 Specific Topics 5 11-17-2010 01:48 PM
please help with trans problem sbsg2005 5.9L V8 Specific Topics 1 10-13-2010 10:42 PM
