Old 04-18-2011, 01:34 PM
xopt1js's Avatar
xopt1js xopt1js is offline
Vehicle: 2010 Dodge Ram QC 4x4
Color: Briliant Black Crystal Pearl/Light Greystone
Rep:39
xopt1js is on a distinguished road
Default Question for SRT-10 rim owners......Help needed with rubbing
OK, so I did a test fitment with my new wheels a few weeks back and found that there was major rubbing. No problem........ordered a set of 1/4" spacers.
Got the spacers last week and installed the rims/tires on the weekend. Got a small problem though............seems as though the drivers side front MIGHT be rubbing while the passenger side has enough clearance and no rubbing.
Now I am not 100% sure that there is rubbing. How do you guys tell? Can you feel it? Hear it? I am pretty sure I rub a little at full lock which is no big deal, but am concerned about rubbing during normal driving.
Seems weird that the 2 sides seem to be different but maybe it's just me being paranoid. I have not gotten an alignment done yet so maybe that will fix it? Perhaps I need to level the truck?
Anyone else encounter this issue? My setup is below so anyone with similar specs please provide your experiences. Thanks in advance.
2010 1500 Laramie
Stock Suspension (No lift or level)
1/4" spacers
20" SRT-10 Replicas
305-50-20 Goodyear Eagle GT2
No alignment done yet
Mopar Chrome Side Steps, 3.92's, Moonroof, Nav/Alpine, Tow Package, Under Rail Bedliner, Extang Trifecta, BT Catch Can, 20% Tint, Mopar All Weather Mats, Tinted Window Deflectors, Mopar Chrome Bug Deflector, Afe Stage II CAI w/ Pre Filter, Black MGP Caliper Covers, Black Stubby Antenna, DeeZee Tailgate Assist, Mopar Power Tailgate Lock, 20" Chrome SRT-10 Replica's with 33" Terra Grapplers
Old 04-19-2011, 12:31 AM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
Look at the tire inside edge for any sign of wear. You can add a leveling kit which I've seen recommended for the size tire you've gone with.
Old 04-19-2011, 10:29 AM
xopt1js's Avatar
Rep:39
There is a slight amount of wear, the problem is that I can't determine if it's from the full lock rub or constant rub. Guess I will have to monitor and see if it gets worse.
As for the leveling kit, I have heard that it will help as well. Just wondering though, if the rubbing is coming from the upper control arm, will a leveling kit actually change the positioning or angle of the upper control arm so it's not rubbing?
Old 04-19-2011, 07:04 PM
FDBDW's Avatar
FDBDW FDBDW is offline
Vehicle: 2009 Dodge Ram
Trim Level: Big Horn, 5.7 hemi
Color: BRILLANT BLACK CREW CAB
Rep:172
FDBDW has a spectacular aura aboutFDBDW has a spectacular aura about
There is a little square pocket that sticks out inside the wheel well directly behind the tire about half way up on the drivers side. I think there is an electrical box behind it, anyway thats were mine rubbed on full lock prior to the level kit. Turn it to full left turn lock then shut the truck off so the stearing wheel will lock in place then get out and look. I would also suggest taking a close look at all the surrounding parts , rub marks are usually pretty obvious . Finally I would suggest a level or lift cause if its that close its gonna be even closer under driving conditions when your hitting bumps or driveways.
MOPAR CAI , 14" MUFFLEX, Diablo Intune 91oct , 2.5" LEVEL, K2 OPEN BLACK MESH GRILLE, FRONT WINDOWS TINTED, ROCKSTARS ON 295/70/18 NITTO TRAIL GRAPPLERS, LARADO BED COVER, DEBADGED, GO RIHNO STEPS , RECON SMOKED TAIL & THIRD BRAKE LIGHTS , PAINTED HEADLIGHTS , SPEEDLOGIX CATCH CAN, FASTMAN PORTED TB ,
Old 04-19-2011, 07:20 PM
xopt1js's Avatar
Rep:39
Got out and had a look today and sure enough there is some serious rubbing.
So what are my options? Will a level fix this? Bigger spacers?
Old 04-19-2011, 07:33 PM
wermbang wermbang is offline
Trim Level: Sport- Off Road
Rep:1930
How close? a leveling kit may help
Old 04-19-2011, 07:35 PM
xopt1js's Avatar
Rep:39
Not sure, I think it may only be at half to full lock.
Would you be able to explain to me how a level with help? Doesn't it just raise the front end? Won't the upper control arm stay at the same spot?
Old 04-19-2011, 07:51 PM
FDBDW's Avatar
Rep:172
Correct me if Im wrong but your 305/50/20 are 32" tall which is an inch shorter than stock but they are 12" wide vs. stock 10.82" wide , so it looks like the width is the problem. So you need to figure out if lifting the truck will alow the tire to clear whatever its rubbing. Maybe jack it up a couple inches and see if it clears, Ive never used spacers so I dont have any input on those. Either way I would suggest taking it to a 4 wheel shop or a good tire shop and get their opinion.
Old 04-19-2011, 08:10 PM
xopt1js's Avatar
Rep:39
Width is definitely the issue as you stated due to the wider 12 or 12.5" tire.
Now that you mention it, when I put them on while the truck was jacked, the tire would spin freely with no rubbing.
Does a level actually change the location or angle of the upper control arm?
BTW, I appreciate your responses as I am new to the lifting world.
Old 04-19-2011, 08:33 PM
Vehicle: 2005 Dodge Ram 2500
Color: Mineral Gray
Rep:177
Well first I'm guessing your rubbing on the control arm?
half to full lock seems like a lot to me. A leveling spacer might adjust the control arm enough to get it out of the way of the tire.
You could try a wider spacer but make sure you feel comfortable with how many threads you have left when you bolt the wheel back on
Maybe look into a wheel adapter if the wheel is rubbing that much
question about 18 in rims ram8923 Dodge Ram Wheels And Tires 13 02-02-2011 06:12 PM
Rubbing Question sfcgaboy Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 3 10-23-2010 12:14 AM
Question Aimed at 17" Rim Owners mineralram 2009 Dodge Ram Forum 1 07-29-2010 02:39 PM
Tire Rims Question for 2010 models... CustomShirts Dodge Ram Wheels And Tires 3 05-07-2010 02:27 AM
Quick question about rims mpoirier2004 Dodge Ram Wheels And Tires 5 02-21-2009 02:18 PM
