Lifting Help! - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 04-18-2011, 07:13 PM
RedRobin RedRobin is offline
Vehicle: 2007 Dodge Ram
RedRobin is on a distinguished road
Default Lifting Help!
I have an 07 1500 4x4 and i have a leveling kit on there with 35's now. i am wanting to put on a 3 inch body lift and then crank the torsion bars about 2 inches and put 2 inch blocks in the rear? will this lift work and look good? well it be pretty high?? if you know anyone with this set up please post pics! THANKS!!
RedRobin
Old 04-18-2011, 07:43 PM
ScatPak07's Avatar
Rep:970
If you do that then you will gain 5" of lift. It will be pretty high since 5" is quite a bit of lift. It will look good with the 35s which is good. I dont know if cranking the torsion bars would be a good idea.....cause if you find them then your suspension is messed up. You have a 2007 Ram which has struts up front. You would need a spacer or you can get the Bilstein 5100s for a better lift. I would say not to do a 2" block in the rear maybe a 1". The 2" would give you the stock rake look, the 1" would make it look pretty level. When the truck is level it actually look taller for some reason. If you like the rake then I guess you could do the 2" in the rear.
Old 04-18-2011, 07:57 PM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
Hi there RR, a big Hello and a Warm Carolina WELCOME! Here's an invitation to drop by the Newbie Checkin to introduce yourself. Also, join our Red RAM group both links are in my SIG below. I hope you make the most of the best RAM ForumZ on the Web!.
Old 04-19-2011, 11:03 AM
PEvil's Avatar
PEvil PEvil is offline
Vehicle: 2007 Dodge Ram 1500
Color: Electric Blue
Rep:41
PEvil is on a distinguished road
I recently installed the Bilstein 5100 leveling shocks on my 07 and put them on the highest setting. It gave me much more lift in the front than I expected, now I am currently trying to decide what size blocks to put in the rear. I would recommend the Bilsteins!
--Superchips 3865 with Advanced Transmission Tuning--K&N Drop-In Filter--Cat-back Exhaust--Sonnax Line Booster--Bilstein 5100 Leveling Shocks--Firestone RideRite Air Springs--AirLift Load Controller II--305/55/20 Nitto Trail Grapplers--
Old 04-19-2011, 01:40 PM
BigHorn 4 Life's Avatar
Color: Briliant Black
Rep:463
Bilstein 5100's all the way!!
Old 04-19-2011, 06:39 PM
okay so if i go with the bilstein 5100's instead of crankin the torsion bars...how many inches of lift can i get from the bilsteins?
RedRobin
Old 04-19-2011, 07:41 PM
dodgeguy's Avatar
dodgeguy dodgeguy is offline
Vehicle: 2000 Dodge Ram 1500
Rep:61
dodgeguy will become famous soon enough
Bilsteins are leveling shocks; at their highest setting they will raise the front of the truck 2.5"
Since you already have a leveling kit on your truck, you don't need these; however, if you don't like your kit, or just want some really good shocks, you can switch out the leveling kit you have on there now with the Bilsteins. (The Bilsteins are better for the truck)
And then, whether you keep the leveling kit or switch to the Bilsteins, you can add the 3" body lift.
If I'm not mistaken (and there's a decent chance I might be, lol - Scat, help!) the 3" body lift combined with the level will be about the same as a 5" suspension lift.
A 5" suspension lift is a full 5" in the front, with 3" or so in the back, so the truck sits level.
That will all look really good with 35" tires.
"If it's smaller than a 5-cyclinder, it's just a glorified motorcycle engine."
Old 04-19-2011, 07:50 PM
Rep:463
That is pretty much right.My Bilsteins say 2.8" lift on the front.So if you do this and a 3" body it will be like having almost a 6" lift.Can you get us some pics of your cv"s?
Old 04-20-2011, 12:35 AM
rclipic's Avatar
rclipic rclipic is offline
Vehicle: 2009 Dodge Ram
Trim Level: TRX
rclipic is on a distinguished road
One thing to note on the Bilstein 5100s. If you're searching on where to buy you may need to use the old model number. I have a '09 TRX4 and was striking out using the new model number (backordered). Searched using the old model number and found them right away with free shipping on shockwarehouse.com. Now let's just hope they're not backordered there too!
Old 04-20-2011, 01:16 AM
Rep:463
Goy mine from 4wheelparts.com.Gl hope you get yours soon.
4x4, dodge, lift, lifted, ram
Really considering lifting my truck -- need some opinions! geddy Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 18 03-18-2011 10:54 PM
Lifting 2wd truck? RumbleBee05 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 64 06-26-2010 12:33 AM
Lifting my 99 dodge ram ext. cab some more. racer965 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 1 06-13-2010 12:26 AM
Sooo ya...umm lifting a 98' 2WD V6 canuckboy Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 10 11-16-2009 02:45 PM
Off-road package lifting...help please!! NE gymnast Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 5 08-25-2009 08:43 PM
