2011 1500 stock - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 04-18-2011, 10:04 PM
Alberto22's Avatar
Alberto22 Alberto22 is offline
Vehicle: 2016 sport crew cab
Trim Level: sport
Color: red
Rep:72
Alberto22 will become famous soon enough
Default 2011 1500 stock
the stock tires I have now are p275-60-r20. I want to use the stock 20"rim but use a wider more aggressive tread. Some one told me go with 33" 12.5, but i have no idea how translated that to tires. Need help. I went to firestone and i left them scratching there heads in confusion. So want I want is to leave the truck alone and add bigger/ wider tires, if possible... Thanks!
The best way to a fisherman's heart is through his fly!
MODS. new truck starting over with the mods lol
Old 04-18-2011, 10:14 PM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
Look at: http://www.discounttire.com/dtcs/tir...T%7Cpc%7C27330 select the optional sizes in these areas to compare.
Old 04-18-2011, 10:24 PM
MTtruckr's Avatar
MTtruckr MTtruckr is offline
Vehicle: 2009 Ram 5.7L
Trim Level: Big Horn Package
Color: Stone White
Rep:50
MTtruckr will become famous soon enough
285/65/20 fits stock, but looks crammed in the wheel well. 305/55/20 will rub. You may be able to fit a 305/50/20 but that is going to a shorter tire which I don't think would look that great.
Use a tire calculator found on google to see different size comparisons, but here is a basic run through on what you are looking at. 33x12.50 is 33 inches tall (what you have now) but 12.5 inches wide. Most 305/55/20's are very similar to this size. They may be 12.5 inches wide but a tad over 33 inches tall.
So a 305/50/20 would be shorter, more like a 32 inch tall tire.
Then say a 285/65/20, it is a bit wider but quite a bit taller.
Then there are some sizes in between. You can find them listed on tire companies sites. I would say you shouldn't go wider than a 285 stock though...not leaving many options. Goodyear Duratrac 285/60/20 is a sweet looking tire that may fit, a bit wider, and is way more aggressive.
Good luck!
BDS 6 inch. Fox 2.0 rear. Toyo MT 35x12.50x18. Yukon 4.56's. Detroit Truetrac. Mufflex 18. Airaid CAI.
Old 04-19-2011, 07:17 AM
scots2413's Avatar
scots2413 scots2413 is offline
Vehicle: 2010 Ram 1500
Rep:19
scots2413 is on a distinguished road
I hope your not worried about gas mileage. Going bigger and wider will kill it. Good luck tho, post pics!
K&N CAI,Flowmaster 50HD,color matched honeycomb grille,Gear alloy 713 Double pump, DSP,Truxx 2" level
Top speed? Stock 1500 w/5.7 Hemi MDM LD RAM - General Discussion 46 12-15-2014 01:55 PM
Which lift kit for 2011 Ram 1500 Sport? sinistersix Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 16 06-04-2011 12:11 AM
help.. 07 1500 want 35x12.5s on my stock 20's HEMIPWR07 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 5 04-01-2011 11:07 PM
2011 1500 5.7 Resonator delete pipe?? BDM218 Exhaust 1 03-27-2011 01:10 PM
2011 1500 Hemi mods MOHog Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 8 02-21-2011 02:47 PM
