Old 04-19-2011, 12:49 PM
paccepounder paccepounder is offline
Vehicle: 1999 Dodge Ram 5.9
paccepounder is on a distinguished road
Default Can coolant in spark well hole result from plenum gasket?
Hello! The truck: 99 4wd 5.9 Sport.
Had a wonderful spark knock start up around 6 months ago, and things are progressively getting worse. My friend is a mechanic, he pulled the plugs and says he saw coolant in the 8th spark plug well, but the compression test checked out just fine. Which confuses me - can a bad plenum gasket cause this? Possible at all. The truck overheated about a year ago due to a bad radiator. I changed it out and all was well for about 3 months and then the spark knowck started, so it may be worse.
Is it possible for me to have blown the head gasket and still get a good compression check? Where would you guys go from here? Dye test?
Thanks for your input!
Also, if you live in the Wilmington, NC area or know anyone who does that wants to make the cash and lead the charge on getting my truck fixed by all means let me know. My mechanic friend has no time and I would rather give my money to someone who can use it rather than the stealership.
-Mike
Old 04-19-2011, 12:50 PM
Rep:1890
No chance that can happen. And yes, you can still pass compression tests.
Old 04-20-2011, 12:33 PM
98redbull2's Avatar
98redbull2 98redbull2 is offline
Vehicle: 2014 RAM 1500 4x4 HEMI express
Trim Level: express blacktop
Rep:52
98redbull2 will become famous soon enough
the plenum gasket only seals the valley from the inside of the intake you might have a cracked head or blown head gasket from the overheating. i would tear it down take the heads off and get them magnafluxed. and start everything fresh.
REDBULL: Red 1998 Dodge Ram 1500 SLT Laramie, 5.2L
Plenum Gasket? toddrod Dodge Ram General Discussion 5 06-26-2012 03:59 PM
Plenum Gasket sixwheeler 5.9L V8 Specific Topics 18 03-09-2011 10:31 PM
Plenum gasket replacement??? DJ7211 5.2L V8 Specific Topics 15 02-25-2011 12:49 AM
just a plenum gasket or possibly more? dirty97ram 5.2L V8 Specific Topics 1 11-30-2010 02:14 PM
Plenum Gasket Leak? Sledneck 5.2L V8 Specific Topics 3 09-11-2010 12:07 AM
