Old 04-19-2011, 06:23 PM
shaneG shaneG is offline
Vehicle: 2007 Dodge Ram
Trim Level: big horn
shaneG is on a distinguished road
Default Recon LED taillights not working
I recently purchased the Recon smoked LED taillights for my 07 Big Horn Ram 1500. When I hook them up, my running lights, and reverse lights work just fine. When I press the brakes or turn on my turn signal, my drivers side light goes out, but the passenger side works just fine. When I try the drivers side light on the passenger side plug, it works just fine. My stock taillights work with no problems. Recon's customer service sucks, they will not help me out with the problem. Does anyone have any suggestions of what might cause this?
Old 04-19-2011, 09:50 PM
manitoba2010ram manitoba2010ram is offline
manitoba2010ram is on a distinguished road
just put a set on my truck and found that they are polarity sensitive. try turning the plug arond in the socket. hope this helps
Old 04-19-2011, 09:53 PM
what do you mean turn the plug around?
Old 04-19-2011, 10:51 PM
the end on the lights that look like a bulb end can go into the factory socket either ways but only one way will work . if you know what i mean? its because the led lihgts on the recon tails have to be positive to positive and negative to negative to work. what i'm trying to say is if the light doesn't work unplug it and turn the plug 180 then plug it back in.
Old 04-20-2011, 09:09 AM
Talking
that worked! Thanks
Old 04-23-2011, 05:33 PM
southpaw5m's Avatar
southpaw5m southpaw5m is offline
Vehicle: 2003 dodge ram 4.7L
Color: Patriot Blue Pearl
Rep:23
southpaw5m is on a distinguished road
Hey Shane I was wondering if you got a hyperlfash on that side as well? before you turned it 180
2nd Gen LED Dash Light Replacement DIY wermbang Dodge Ram Knowledge Base 3 01-08-2012 10:25 PM
Recon LED taillights question southpaw5m Electrical 1 04-12-2011 03:26 PM
Recon led cab lights 11BMopar Custom Dodge Ram Exterior Modifications - Body Mods - Body Kits 30 04-10-2011 02:53 PM
Frustrated at RECON 09 TRX AGGIE Custom Dodge Ram Interior and Exterior Lighting 5 01-07-2011 02:55 PM
Recon LED Tail Lights on 07 RAM 1500 City Slicker Custom Dodge Ram Interior and Exterior Lighting 27 02-08-2010 06:01 PM
