Removing a headlight housing - 09 Ram - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Body & Interior
Old 04-19-2011, 10:02 PM
PenacookRam PenacookRam is offline
Vehicle: 2009 Dodge Ramm 1500
Trim Level: SLT 1500
PenacookRam is on a distinguished road
Default Removing a headlight housing - 09 Ram
I'm looking to put some hideaway strobe lights in the headlights of my 2009 Dodge Ram 1500. Does anyone have, or know where I can find, detailed instructions on how to remove the headlights so I can do this? Thanks a bunch!
Joe
Old 04-19-2011, 10:28 PM
libertyfiremedic libertyfiremedic is offline
Rep:54
libertyfiremedic will become famous soon enough
I'll walk you through it.... hopefully I can paint some good pics since its late and I don't have pics.
Open hood, Remove the shroud that is on just behind the grille (there are 6-7 plastic "trees" that hold it in.) Then remove the 4 10mm bolts that hold the grille in place at the top. (I put a towel or blanket between the grille and the top of the bumper at this point) Lean the grille forward to relase the clips at the bottom of the grille. Remove grille. Remove the two 10mm bolts on each headlight..... nows the tricky part... inside the fenderwell there is a door in the front. Open it. Inside there is a white plastic "locking lever"... unlock the light by pushing the lever up... at this point the light is ready to remove. Go back to the front of the truck and pull the light assembly forward. It should come out with just a little pull.
With all that said.... just check out this link http://ramforumz.com/showthread.php?...dlight+removal
Old 04-19-2011, 10:33 PM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
Here is my HID install thread with all the pics of the lights coming out
http://ramforumz.com/showthread.php?t=70224
Old 04-19-2011, 11:48 PM
platinuminjected's Avatar
Vehicle: 2009 dodge ram 1500
Rep:713
both are excellent threads and info to follow!!!! hope it helps ya out bud!!
Headlight Housing AKFossil 2010 Dodge Ram Forum 0 12-01-2010 12:41 AM
Removing Headlight (2008 Dodge Ram) tb08ram Custom Dodge Ram Interior and Exterior Lighting 9 11-25-2010 05:58 PM
Headlight Housing Johns HEMI 2500 Custom Dodge Ram Interior and Exterior Lighting 6 03-30-2010 08:32 PM
Finally 2009 projector headlight and housing for 2009 ram 1500 truckin2009 2009 Dodge Ram Forum 6 01-08-2010 01:43 AM
Removing Headlight Assembly medic269 Custom Dodge Ram Interior and Exterior Lighting 4 08-08-2009 03:08 AM
