Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Electrical
Electrical 1st Gen Dodge Ram Electrical Problems and Questions.
Old 04-19-2011, 10:54 PM
Terry Morgan Terry Morgan is offline
Vehicle: 1989 Dodge Ram 250
Engine: 1989-1992 360ci (5.9L) LA V8 190hp
Terry Morgan is on a distinguished road
Default '89 Ram 250 won't start
I'm trying to get my 89 Ram 250 to run, it cranks but won't start, no juice
to plugs or coil. I
think it's a 318 engine, pic attached. I located a '60 way switch' (noted in the Chilton) near the
battery and headlight, I have only Haynes and Chilton manuals. Is it worth
it to buy the manual, the cheapest price is $70.
Old 04-20-2011, 12:33 AM
bdrouhard15 bdrouhard15 is offline
Vehicle: 1993 chevy w/t
Color: Grey
bdrouhard15 is on a distinguished road
Well it is defiantly a 318 or 360. Do you know if its getting fuel?
Old 04-20-2011, 01:00 PM
Color: Grey
Sorry about that bit tired last night getting fuel doesnt matter if your not getting a spark.
Old 06-02-2011, 12:38 AM
jpmassa jpmassa is offline
Vehicle: 1991 Ram D250 5.9L
Trim Level: LE
Color: White peeling to primer
jpmassa is on a distinguished road
Similar problem on my 1991 D250. Battery, plugs, wires, distributor, pick-up coil, voltage coil all looked good, but little or no spark. Turned out to be the SBEC / engine computer. There were no fault codes on the readout. Replaced it with a remanufactured ($180) one and the starting problem was solved.
Old 01-30-2014, 09:00 AM
quote
unquote
how did you figure out it was the computer?
I can't PM until I have 25 posts, I have 4, I'm not making 21 spam posts
Old 01-30-2014, 01:16 PM
Gen1dak Gen1dak is offline
Vehicle: 1990 RamCharger
Rep:85
Typically, one way to tell is if there are no trouble codes. "Dead computers have no memories." Even if everything is fine, you'll at least get code 55, which means "end of line (report)". If you don't even get that, it's toast. Plus, if
it's already had a replacement computer (they're all remans) it won't last as long as the OEM. My '90 is on computer #3 as far as I know, but maybe more. By the time I got it, it was already 17 years old. The last one I replaced just a few months ago started running erratically....the timing was bouncing around. It steadily got worse. New computer straightened that right out. Had codes, but it was still fading on me. There are FSM's on CD for less than $70. I got an original book years ago, and yes, it's worth it. Granted, you actually have to read the thing, but the info is there. The Haynes manual is a basic thing, has uses, but you'll see many things in one where it says, a thing is too complicated and you should seek professional help. The FSM is what the pros use.
2005 Dodge Ram 3500 Diesel help please wont start.. Hendogg Cummins Diesel Specific Topics 5 03-30-2011 04:23 AM
Remote start tip snyds 2011 Dodge Ram Forum 3 03-16-2011 09:23 PM
Remote start does not work with low fuel sportcrewMI 2010 Dodge Ram Forum 10 11-22-2010 11:18 PM
new truck at 50 miles and wont start rich1500 2010 Dodge Ram Forum 11 08-05-2010 09:48 PM
2010 doesnt always start after remote start bigdadsram Electrical 1 12-15-2009 09:27 PM
