Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Towing
Towing 2nd Gen Dodge Ram Towing Questions
Old 04-20-2011, 09:58 AM
JRam's Avatar
JRam JRam is offline
Vehicle: 2011 Dodge Ram 1500 crew
Color: gray
JRam is on a distinguished road
Angry Towing issues and rear differential
We just bought a 2011 Ram 1500 crew cab sport with a max tow rated at 10,020 lbs.
We have a 6600lb (dry) trailer with tongue weght of 630lbs. We had no water in it and typical stuff in the bed...cooler, generator, some fire wood and luggage...maybe 200lbs. Driving up some good grades from Phoenix to Payson, we smelled a very strong smell of rear differential fluid. I know that smell as we previosly had a Aramada and blew out the RD towing a few years back. Bought the Ram as I thought it was capable. Anybody have an idea why this is hapenning again? Could it be to much tongue load? The Ram back end was riding real low..again a weight factor, but think it should handle it. Anybody else have this problem?
Old 04-20-2011, 11:47 AM
charlieb's Avatar
charlieb charlieb is offline
Vehicle: 2017 ram express quad cab
Trim Level: express
Rep:33
charlieb is on a distinguished road
you can buy a point and read hand held thermometer 30.00 bucks. when i tow having loads(6-9k) rear diff temp is 60 celcius front 40 celcius back brakes 60-70c front brakes 110c. u can buy after market diff cover that holds 2x the fluid and has cooling fins 200-300 bucks will definetly run cooler.dont know if urs runs hotter then mine but i have never smelt anything.im canadian so celcius is how i measured u will have to do conversion for comparison plus these temps were taken when abiant air was 10 celcius after 120km drive towing dual axle 8 thousand pounds.
Old 04-22-2011, 02:09 PM
JRam's Avatar
Color: gray
Thanks Charlieb...might check out a heat therm.
does dodge ram have issues with rear ends on there trucks ? nitro1965 5.7L V8 Specific Topics 12 10-24-2016 06:46 AM
Towing issues chris66 Towing 19 03-08-2012 05:36 PM
Rear Differential Noise shocker Dodge Ram 4x4 - Offroad Discussion 8 03-24-2011 11:07 PM
Resolved - rear end loose metal sound, reverse rubbing, burning smell jjsmithii 5.7L V8 Specific Topics 2 02-25-2011 02:13 AM
Max Towing Weights for the 1500 Bellzy Towing 4 03-23-2010 01:48 AM
