Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Suspension
Old 04-20-2011, 10:21 AM
redrumrevolution1 redrumrevolution1 is offline
Vehicle: 2004 Dodge Ram
Color: silver
redrumrevolution1 is on a distinguished road
Default Abs problems
My abs light came on about 2 weeks ago out of no where. I recently changed my rear brake pads about a month ago and my front pads about 4 month ago. The brakes pedal also vibrate a little bit when coming to a stop. This only happens on a couple of stops after i start up the truck. The brakes also stick a least once after starting up the truck and driving it. Would could be the probable causes of this issue?
Old 04-20-2011, 10:32 AM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
A big Hello and a WarmCarolina WELCOME! I hope you make the most of the best RAM ForumZ on the Web!
I wonder, did you have the roters turned when you did the pads?
Drop by the Newbie Checkin and introduce yourself, use the link in my SIG.
Old 04-20-2011, 10:46 AM
Color: silver
No the rotors were not turned. Could this make the abs light come on because the light is on even before i start driving the truck
Old 04-20-2011, 04:09 PM
RedRam10's Avatar
Rep:743
I was thinking about the vibrations, have you checked at an auto shop to have them read the code that has been set?
Old 04-23-2011, 07:28 PM
Color: silver
I replaced the abs rear speed sensor, but the abs and brake lights are still on. I haven't felt any vibration but im not understanding why the warning lights still on.
Old 04-26-2011, 05:33 AM
Vehicle: N/A
Rep:1045
yes the rotor thats not turned could cause the vibs. ive been lookin into the brakes pretty heavily as my front disks are shot. as for the abs light, best to see what code is poping up. could be nothing for that matter. mabye it tripped when the brakes were worked on?
Old 04-26-2011, 06:48 AM
UltraFlame's Avatar
Vehicle: 2007 Dodge Ram Quad
Rep:840
I have had the same problem intermittently and have replaced speed sensor also and have new pads and rotors. I now think it is the front left hub that has the ABS sensor in it so I may replace the hub.
Old 04-27-2011, 12:33 AM
Color: silver
I replaced both front hubs some time in the past year, so I dont think it will be my hub. Could there be any other causes?
Old 05-09-2011, 02:11 AM
RAMING IT's Avatar
RAMING IT RAMING IT is offline
Vehicle: 2002 DODGE RAM
Trim Level: QC SLT 2WD
Color: Almond Pearl, Blacked Out
Rep:65
RAMING IT will become famous soon enough
I might be wrong but I read somewhere (think it was haynes) that there was an abs sensor in each front hub and one on the rear diff. Total of 3
Heavy A$$ truck w/ ported stock heads, intake / heads gasket matched, keg mod, iat mod, cks mod, 2 tone vinyl wrap, blacked out trim, (pcm junkyard mod)
leveling kit problems? jaybull Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 12 10-27-2014 11:32 AM
problems rainhater1 2010 Dodge Ram Forum 0 02-21-2011 08:45 PM
Another HID problem(s)! Wrkinprogress Custom Dodge Ram Interior and Exterior Lighting 7 10-25-2010 03:05 PM
2005 engine problems and questions 05Blackout 4.7L PowerTech V8 Specific Topics 6 08-02-2010 10:16 PM
any common problems for 00 ram 1500 5.9? mmoore0219 5.9L V8 Specific Topics 12 06-28-2009 03:08 PM
