Old 04-20-2011, 02:12 PM
Fireguy87's Avatar
Fireguy87 Fireguy87 is offline
Vehicle: 1996 Dodge Ram 1500 4X4
Trim Level: Laramie SLT
Rep:14
Fireguy87 is on a distinguished road
Default 1996 Ram 5.9L Problem (HELP!!!)
I just bought a 5.9L 360, with the auto trans. It seems like around 1-25 mph it stutters really badly, like it's not getting fuel or not shifting. If I accelerate very slowly, or gun it, it it doesn't do it. Any help would be greatly appreciated.
Old 04-20-2011, 02:46 PM
ramvan2500's Avatar
Trim Level: SLT - 2500
Rep:128
I would certainly spend a weekend to clean the throttle body and to change the oil and oil filter, the breather filter, sparkplugs, pcv valve, air filter, check the distributor cap and clean it or replace it if needed, check the wireset. Also try doing a compression test. Replace the transmission filter and gasket, be sure to top off the atf fluid with atf+4. add a little seafoam to the fuel to clean out the valves and injectors. if you want add seafoam to the oil about 100 miles before you change the oil. keeping things clean and fresh usually helps. also you might want to check the rear differential, possibly replace the fluid along with the gasket and if you do change the gear oil be sure to add an additive, this helps with all sorts of problems and prevents problems as well.
Old 04-20-2011, 04:13 PM
teamarctic14 teamarctic14 is offline
Vehicle: 1999 dodge ram 2500
Color: green
teamarctic14 is on a distinguished road
sounds to me like its skipping or misfireing is the engine light on i would do a full tune up plugs wires cap rotor ex.
Old 04-21-2011, 12:22 AM
Fireguy87's Avatar
Rep:14
No check engine light. Someone who drove it suggested transmission clutch bands????
Old 04-21-2011, 07:36 PM
98redbull2's Avatar
98redbull2 98redbull2 is offline
Vehicle: 1998 Dodge Ram 1500 4x4
Trim Level: SLT Laramie quad cab
Color: red
Rep:52
98redbull2 will become famous soon enough
basically check to see if it actually needs a tuneup and check the transmission fluid for color and smell to get a start but if you can hear the engine stuttering check that, also check for a leaking plenum gasket. cleaning the throttle body takes 5 mins but make sure you check everything.
REDBULL: Red 1998 Dodge Ram 1500 SLT Laramie, 5.2L
Old 04-23-2011, 08:42 AM
RAMING IT's Avatar
RAMING IT RAMING IT is offline
Vehicle: 2002 DODGE RAM
Trim Level: QC SLT 2WD
Color: Almond Pearl, Blacked Out
Rep:65
RAMING IT will become famous soon enough
When you say you gun it and nothing happens does the engine rev up at least? Or the same amount of sputtering is consistant regardles of the amount of pedal pressure you put down?
Heavy A$$ truck w/ ported stock heads, intake / heads gasket matched, keg mod, iat mod, cks mod, 2 tone vinyl wrap, blacked out trim, (pcm junkyard mod)
Old 04-24-2011, 04:33 PM
Fireguy87's Avatar
Rep:14
It seems as if the transmission is slipping going into 2nd. if I accerate quickly, or extremely slowly it wont do it,
Old 04-24-2011, 08:08 PM
RAMING IT's Avatar
Rep:65
Try adjusting your kickdown cable.
Old 04-24-2011, 09:59 PM
Fireguy87's Avatar
Rep:14
Cool!! wait... how?
Old 04-25-2011, 01:40 AM
RAMING IT's Avatar
Rep:65
Cool Here Ya Go
Originally Posted by Fireguy87 View Post
Cool!! wait... how?
Hope this helps. http://viewer.zoho.com/docs/f3a9cb
Transmission Problem 07 Hemi 07Ram 5.7L V8 Specific Topics 14 03-14-2013 07:45 PM
1996 ram 1500 transmission problem chadartfunkal 5.2L V8 Specific Topics 3 11-15-2012 09:33 PM
Things I should look out for when buying a used 1996 dodge 2500 5.9L Jersey Ram 5.9L V8 Specific Topics 7 04-07-2011 07:49 PM
Door Ajar Light & Power Windows Problem. scottdutton Electrical 1 12-05-2010 05:54 PM
Yet another HID problem griffin407c Custom Dodge Ram Interior and Exterior Lighting 10 10-27-2009 05:37 PM
