ac and heat - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 2nd Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 04-20-2011, 03:21 PM
teamarctic14 teamarctic14 is offline
Vehicle: 1999 dodge ram 2500
Color: green
teamarctic14 is on a distinguished road
Default ac and heat
in my 99 ram 5.9l when i have my ac on it blows through the vents when i come to a hill and it needs more power it swtiches to the winsheild then it will swtich back to the vents same if im i step on the gas just to say passing someone when it needs more power it will do the same thing. same way if i have the heat on the vents it would switch to the windsheild
Old 04-20-2011, 04:37 PM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
Don't know where to point you, have you pulled the control panel out to see if there are any loose connections or if there is a loose vacuum line under the hood?
Old 04-20-2011, 04:55 PM
Color: green
yes i have had the dash cover off and control knobs out and all the lines seem good and under the hood everything looks good there also
Old 08-05-2011, 01:07 PM
awj63 awj63 is offline
Vehicle: 2001 Dodge Ram 1500 Quad
awj63 is on a distinguished road
Default Replace the check valve
This is a known problem on the trucks, under load the ac switches to defroster vents. It is due to a faulty check valve in the ac line going to the ac heat control module.
Old 08-05-2011, 01:18 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1388
I agree with redram, it sounds to me like vacuum line leak. Not sure if on the ram the vents are operated by vacuum, but would bet they are, I know my 1997 s10 had vacuum lines that operated the vent doors and on the highway it wouldn't work properly(they were dry rotted/cracked, replaced them and it was like new). Try finding a diagram and start with vacuum lines, they are cheap.
Sean
No Speedo... Brake light on... ABS light on... Heat stuck on full heat... No reverse lights... HELP! kohlep0a Electrical 9 10-04-2011 07:36 PM
Heat on one side only mopar02 Electrical 13 07-01-2011 11:22 AM
heat issue driving me nuts Love My 1500 Heating & Cooling 14 11-01-2010 12:32 AM
1990 Ram Charger Poor Heat ltreff Heating & Cooling 2 11-14-2008 10:03 AM
