Old 04-20-2011, 07:14 PM
dagatago dagatago is offline
Vehicle: 2006 2500 Dodge Ram
Trim Level: Thunder road
dagatago is on a distinguished road
Default Will they fit ???
I own a 2006 2500 4x4 With a level kit installed... Its time for new tires and I'm wondering if 295-70-17 tires on my factory rims will be a problem ? ( rubbing )Also anyone have pictures of this combination ???
Thanks in advance.
Newbie
Old 04-21-2011, 12:30 AM
williamhartle's Avatar
williamhartle williamhartle is offline
Vehicle: 2007 dodge ram
Trim Level: st
williamhartle is on a distinguished road
295 70 or 285 70
either way u should have no problems
2 inch leveling lift 3 inch body lift, 34" bfg mud terrain TA KM2, straight pipe, vararam intake, superchips cortex, Firestone air bags, skyjacker n8000 shocks rear, s8000 front struts, painted head lights, tinted tail,cab mount light, big shiny chrome balls.
Old 04-21-2011, 12:35 AM
TxPride911 TxPride911 is offline
Rep:27
TxPride911 is on a distinguished road
You should be able to go even bigger if you wanted too. A 305/55/20 fits on mine stock on a 1500 and I know the 2500's sit a little taller. A 305/55/20 tire is about 33inches taller if not more so you could go a little bit more with the 17's.
Old 04-21-2011, 07:52 AM
jcasey10's Avatar
jcasey10 jcasey10 is offline
Vehicle: 2002 Dodge Ram
Trim Level: SLT Quad Cab
Rep:869
You should be alright with a 295. I've seen guys run 35's with stock wheels on 2500's. Even though the backspacing isn't ideal on the stock wheels, the leveling kit will help you out.
