Dodge Ram Decals
Old 04-20-2011, 06:53 PM
CCCC CCCC is offline
Vehicle: 2001 Dodge ram
CCCC is on a distinguished road
Default Front hubs not locking
Had my 2001 2500 6 speed manual 4wd out in the rough this morning and when needed, the front hubs did not lock. Transfer case shifts/selects as normal but no "4wd" light and no locking hubs for the first time in 188k miles.
I have read the manual and see the vacuum driven mechanism (vacuum motor?) comments, but would like any expert experience and knowledge before I dig into the problem. What are the most common causes of this issue? Is it more likely a vacuuum leak or a vac tube off - or do the vacuum motors go bad? Is there one vac motor or two - one for each wheel?
Thanks for any help.
CCCC
Old 04-20-2011, 09:07 PM
69speeder69's Avatar
69speeder69 69speeder69 is offline
Vehicle: 2001 Dodge Ram
Trim Level: Laramie SLT
Rep:18
69speeder69 is on a distinguished road
I had the same issue a month ago. The vacuum lines were old and brittle. And had a small crack in one. Replaced with some new vacuum hose and works perfect now.
Old 04-21-2011, 12:08 AM
Thanks 69speeder69 - I will look there first, although never have noticed that tubing. If you don't mind my asking, how long are the vac tubes and how are they routed?
Actually, as a newbie I messed this up - meant to post the thread in the 5.9 Cummins diesel area. Am hoping that the 2500 4wd setup is the same as in the gas version.
Old 04-24-2011, 07:32 PM
Rep:18
Well I went to use my 4H today and of course now that i said something for some reason isnt working either now. And as far as whether or not they are the same I am not sure. But they are two small hoses coming off the back of your front axle.
Old 04-24-2011, 09:55 PM
beave928 beave928 is offline
Vehicle: 1999 dodge ram 2500
Color: whitw
beave928 is on a distinguished road
Also that motor is a vacuum engaged actuator when it begins to suck that actuator slides a fork over in which the gear sits, you can try to replace that actuator and check for vacuum leak first but if you want to eliminate that problem all together look online for a kit called the posi-lock it manuelly engadges your front end from the cab at the push of a button. Your floor selector will determin whether you are in high or low.
Old 04-29-2011, 10:13 PM
Rep:18
Just discovered this while searching for answers to my problem. Hope it will help you with yours
Diagnosing 4X4 Engage Problems
If you like to four-wheel, brush on the trails can rip the vacuum lines from the axle CAD. Carefully check the lines between the frame and the CAD diaphragm, for damage or oil contamination. Numerous people have ripped the lines loose and one person has found that transmission fluid dripping onto the vacuum lines caused them to swell and leak. If there is no obvious damage, proceed with the diagnosis below:
> I have a 97 RAM 1500 Club Cab Sport 4 X4 and I am having
> a problem with the 4 x 4 High and Low engage light.. it just
> will not come on when I put the truck into 4 wheel drive......
> ANY SUGGESTIONS ???
If this truck was mine I would:
1. Shift into 4WD and move truck a couple of feet
2. If light is still off, park truck, block the wheels, set the park brake, jack right front wheel, and try to hand spin the wheel
* If wheel doesn't turn, 4x4 is functioning properly but there is a wiring problem: use an ohmmeter to check the 4x4 switch, wiring, fuse, and bulb.
* If wheel turns freely, the front axle or transfer case is not engaged: continue...
3. Attempt to hand spin the front driveshaft If the driveshaft WILL spin, the transfer case is not engaged Check the transfer case shift linkage, problem is in linkage (or in the tran$fer ca$e internal$ <-- yes this means $$, ouch!)
* If the driveshaft will NOT spin, the transfer case is engaged properly: continue...
4. USE CAUTION! With transmission in neutral or park, start engine, measure vacuum on the two vac lines at front axle shift motor. One line should have approx 20" vacuum, other line should have none.
* If NO vacuum measured, look for vacuum leak or bad vacuum switch.
* If both lines have vacuum, look for a bad vacuum switch or ruptured CAD actuator diaphragm.
* If one line has 20" +/- vacuum:
o Move transfer case lever to 2WD, measure vacuum again. Lines should have swapped vacuum signals.
+ If No: vacuum switch bad or 4WD shift linkage needs adjusting
+ If Yes: Vacuum motor bad or stuck, or shift fork stuck: continue
5. Remove vacuum shift motor from the axle, attach vac lines to shift motor, engage/disengage 4WD. Does shift motor plunger move at least 1/2"?
* No: shift motor bad
* Yes: Check axle shift fork and vacuum motor for binding
Old 05-02-2011, 04:10 AM
BarryK BarryK is offline
BarryK is on a distinguished road
I had a similar problem. The cause was a vacuum leak in a small plastic vacuum line a couple of feet back from the front axle. Once the leak was repaired it engaged just fine.
Barry
Old 05-07-2011, 08:11 PM
Killburns's Avatar
Killburns Killburns is offline
Vehicle: 2001 dodge ram 1500
Trim Level: LS
Color: Green
Killburns is on a distinguished road
I just installed this on my truck will get rid of the vacuum lines all together so you never have to worry about your truck not engaging again. Here is a link to what I got.
http://www.4x4posi-lok.com/app_dodge.html
2006 vibration 55mph rake1 Suspension 41 03-07-2014 08:52 PM
instructions to enable front seat video in motion partypooper 2010 Dodge Ram Forum 20 08-05-2011 06:14 PM
Front Driveline Question herc 2011 Dodge Ram Forum 7 04-19-2011 04:35 PM
04 dodge ram front differential noise timhorton Newbie Checkin! 10 09-24-2010 10:48 PM
Charlie again ! Re prev post front end howl charlie Cummins Diesel Specific Topics 2 01-20-2010 09:26 PM
