Old 04-21-2011, 10:51 AM
Wildcat's Avatar
Wildcat Wildcat is offline
Vehicle: 2010 Dodge Ram QC 4x4
Color: Mineral Gray Metallic
Rep:166
Wildcat has a spectacular aura aboutWildcat has a spectacular aura about
Pull the Fob apart and clean the battery and terminals. Mine was doing this too, but a quick cleaning and it works like new. If you keep the keys in your pocket, like most of us do, lint finds its way in there and causes a bad connection.
Cobra CB, Dual antennas, Dodge molded splash guards, Tekonsha P2 brake controller, Weatherguard tool box, AirLift 1000 helpers springs, Line-X bedliner, B-Pillar tape removed, 35% tint front windows.
http://i842.photobucket.com/albums/zz347/kcwildcat1/Wildcatsig.jpg
Old 04-21-2011, 11:17 AM
rodanst6 rodanst6 is offline
Vehicle: 2014 Dodge Ram 1500
Trim Level: Limited
Color: Blue
rodanst6 is on a distinguished road
I believe that the remote start works with radio transmission, there is an antenna behind the glove box if what I was told by the dealer is correct. Maybe the lightning is interfering with that or there is a short that is causing the problem. Just some ideas, I am having the remote start put on today and will pose the question to the service guys at my dealer.
Old 04-21-2011, 06:39 PM
kap64's Avatar
kap64 kap64 is offline
Vehicle: 2011 Dodge Ram
Color: Deepwater Blue
Rep:45
kap64 is on a distinguished road
Here's another question for you, why does the alarm go off when you use the emergency key to get in? I can unlock the door and as soon as I pull the handle, the alarm sounds. I'm kind of glad to see I'm not the only one with this issue. Oh, and another weird one, when I activate and pair my cell phone to the truck, the phone cuts off and reboots repeatedly until I disable bluetooth...
Old 04-21-2011, 07:51 PM
Rep:2657
when i first bought my Ram a bit better than 2 years ago
i was having FOB problems, the dealer tried replacing the FOB batteries, it didn't help
one day it was raining HARD, i had my arms full of groceries, FOBs didn't work, i had to use the Valet key, opened the door & put the FOB into the ignition & started it.
Next day i was sitting in line at the dealership at 7:30 am, they couldn't do anything for me that day, but, they did order 2 new FOBs & they called me the next day to come in & get them, they also did some kind of FLASH & in the last 18 months, maybe a hand full of times i had to press the Unlock function more then once, i use the Start function most of the time when its chilly
by the way FOB is short for FOBIK, which stands for Frequency Operated Button Integrated Key
sometimes Automatic Doors, CNC machines, etc, can cause radio interference
Old 04-21-2011, 08:26 PM
garner's Avatar
garner garner is offline
Trim Level: Lonestar
Rep:46
I already answered this. Post 4. Also says in owners manual under getting started and then under theft alarm. Says that the alarmed is disarmed when you press the key FOB unlock button or turn the ignition to the on/run position
Gone but not forgotten:
First 2011 Ram R/T in Texas
Old 08-24-2011, 05:15 PM
mike49 mike49 is offline
Vehicle: 2009 Dodge Ram 1500
Color: tan
mike49 is on a distinguished road
Originally Posted by belle View Post
I have 5800 miles on my 2011 Ram. The original key fob has started to work only when it wants to. My backup one works fine. The dealer told me to bring both in for reprogramming. I'll let you know what happens.
I thought the FOBIKs could NOT be re-programmed
Old 08-26-2011, 11:15 PM
crazyrealtor's Avatar
crazyrealtor crazyrealtor is offline
Vehicle: 2011 RAM CREW CAB SPORT
crazyrealtor is on a distinguished road
both of my fobs started doing this on my 11. I have to smack it and it then works. I will be going to the dealer to have them replaced. Hope this helps
2011 Ram Sport crew cab 4x4 Deep Water Blue
