Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Suspension
Old 04-20-2011, 11:42 PM
breck83 breck83 is offline
Vehicle: 2006 dodge ram 1500
breck83 is on a distinguished road
Default problems removing the lower strut bolt on 2006 1500
so i am trying to install a leveling kit and i cant get the lower strut bolt to come out. i can get it to turn but the bushing is stuck to it and is now damaged. i cant find the bushing anywhere! dodge says that i need to replace the whole lower control arm and they want about $500.00 for it! anyone know of any other options?
Old 04-21-2011, 12:37 PM
PEvil's Avatar
PEvil PEvil is offline
Vehicle: 2007 Dodge Ram 1500
Color: Electric Blue
Rep:41
PEvil is on a distinguished road
I'm not sure where to get the bushing but when I removed my struts, I took the nut off the lower bolt and used an air chisel to push the bolt thru. I just made sure I was centered on the bolt and let her have it.
--Superchips 3865 with Advanced Transmission Tuning--K&N Drop-In Filter--Cat-back Exhaust--Sonnax Line Booster--Bilstein 5100 Leveling Shocks--Firestone RideRite Air Springs--AirLift Load Controller II--305/55/20 Nitto Trail Grapplers--
Old 04-25-2011, 03:42 PM
i will give that i try, thanks
Old 05-31-2011, 12:04 PM
djod1985 djod1985 is offline
Vehicle: 2007 Ram 1500
djod1985 is on a distinguished road
Did you get it out? I had the same issue this weekend on a 2007. Couldn't get the bolt out of the driver side. Glad I started on that side and not the other or I would have had to take it all apart again and take out the leveling kit. I am looking for a strut bushing kit. Hopefully I can find one...
Old 06-01-2011, 10:44 PM
sullivan's Avatar
sullivan sullivan is offline
Vehicle: 2006 Dodge Ram Sport 5.7
Rep:202
sullivan has a spectacular aura aboutsullivan has a spectacular aura aboutsullivan has a spectacular aura about
Dude, hammer the ****ing bolt out. And get a new strut bushing.
Or get new struts which will have bushings installed already.
06' Sport - 3.92 Gears - Superchips - Bilstein Shocks - HellWig Anti-Sway Bar - Cooper Zeon LTZ - Viper Alarm & Remote Start - Halo Projector Lights - 5k HID Lows & Fogs - Custom Emblems - Magnaflow - CAI
Old 10-06-2011, 10:13 PM
justin35 justin35 is offline
Trim Level: slt big horn
Color: red
justin35 is on a distinguished road
Default same problem on 2006
having the same problem. did you find anything that works? i got both driver side and passenger side so beat to death i barley got the nut to thread back on. need less to say i didnt get my leveling kit on.
Old 03-05-2012, 10:36 PM
waltersgjr waltersgjr is offline
Trim Level: sLT
Color: Inferno Clearcoat
waltersgjr is on a distinguished road
I am having the same problem with a 2006. Is there a lower strut bushing available?
Old 03-12-2012, 02:59 PM
LJSRam's Avatar
LJSRam LJSRam is offline
LJSRam is on a distinguished road
I have the same problem and I ended up taking the truck to a shop. They did say NAPA has the bushings needed. I don't have the part nunber but i asked him a few times and he said he had one sittiing in the wearhouse if it was needed.
Old 03-15-2012, 01:25 AM
jankinnu jankinnu is offline
Vehicle: 2006 Dodge Ram 1500 4x4 Hemi
jankinnu is on a distinguished road
I just installed 2.5" lift kit to 2006 4x4 Ram 1500. The lower strut bolts were stuck. I had to go and buy a big hammer, sprayed WD40 and gave the bolts heavy beats. I used long socket that fit at the end of the bolt so I didn't damage the bolt by beating the socket end. I also had impact wrench.
Once bolt start moving a little, I used impact wrench and WD40 until the bolt was spinning easily. After that I kept hitting the bolt back and forth with hammer to get the dirt out. It took a couple of hours but I got the bolts out.
Old 04-18-2014, 06:19 PM
mumptia mumptia is offline
Vehicle: RIP 2001 cummins, 2009 Hemi
mumptia is on a distinguished road
Just putting a 3" front and 2" rear leveling kit on my 09 1500 as I type.
Back went on really slick. My 15 year old did most of it.
Now I'm on a date with the two lower front struct bolts who are being a primo b__ch. Been at it for about 3 hours now.
Here's what I did
1. Cut the excess thread off the bolt.
2. Sniped the bolt and broke the bushing free.
3. Cut off the head of the bolt
4. Stretched the shackle of the strut wider than the bushing and removed the strut
5. popped the bushed out and pounded the snot out of what was left inside.
Hint: The head side of the bolt has a step on it for about a 1/2" below the head itself. Do your pounding from the thread side because the threads have a slightly smaller OD.
6. Then popped the bushing back in and tomorrow I'll get new lower strut bolts.
Have to get it done asap, I have a wheel alignment appointment tomorrow at 1! lol
Hope this helps avoid a bunch of head scratching.
How to lower a 2009 ram 1500 waldig Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 5 11-19-2012 11:32 PM
lower control arms cam bolt tuckertrucker Suspension 2 02-25-2011 01:25 AM
2006 Ram 1500 Front Steering Arm Problem NitroMagnum Newbie Checkin! 11 06-03-2010 11:43 PM
lowering my 2006 1500 mega cab boltster Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 8 05-10-2010 04:25 PM
Best way to lower a 05-06 Ram 1500 Jaycan Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 13 12-08-2009 08:29 PM
