Old 03-06-2014, 07:56 PM
pamegacab pamegacab is offline
Vehicle: 2007 Dodge Ram 2500 Mega Cab
pamegacab is on a distinguished road
Default Power steering problem
I have an 07 megacab hemi and after some offroad adventures noticed the wheel was getting hard to turn. I replaced the power steering pump which seemed to remedy the problem a little bit, but just 2 days later it was back. Now if I am stopped at idle i cannot turn the wheel at all. I have to be on the gas to get the wheel to turn. When on the gas everything feels fine.
Did the power steering pump go out again, or is my steering gear messed up? Also worth noting I did not see any signs of pinched lines and when I drained the old fluid it was a normal color. It also is not leaking as far as I can see. The high pressure line was also replaced maybe 2 years ago as well.
Any help is appreciated!
Old 03-06-2014, 08:10 PM
hemi4452's Avatar
hemi4452 hemi4452 is offline
Vehicle: 2013 ram crew cab sport
Color: True blue pearl
Rep:69
hemi4452 will become famous soon enough
What kind of pump did you buy. I went through 2 after market pumps from nappa and where both bad. My friend said he had same issue with after market pumps on a durango. Didnt want spend $300 on a new one so I went to the junk yard and got a factory one used for $45
Old 03-17-2014, 08:00 AM
mopar magic mopar magic is offline
Vehicle: 2001 Ram 1500 QC 4x4
mopar magic is on a distinguished road
sounds like a bad pump. I currently have the same issue on my 01. if you bought it from a chain store like autozone, napa, oreillys, etc it's not uncommon to get a dud once in a while as they are not "brand new" parts, only reconditioned. it's up to you if you wanna try your luck again and swap the pump under the warranty or bite the bullet and buy new to guarantee no more problems. I've seen new pumps for < $300 just search around online
Old 03-18-2014, 08:15 PM
Simple guy Simple guy is offline
Vehicle: 2003 Ram 1500
Trim Level: SLT QC 4x4
Color: Mineral grey
Rep:109
Simple guy will become famous soon enoughSimple guy will become famous soon enough
Is the reservoir foamy or bubbly? Might have a leak that is sucking in air. If it is I'd start looking on the suction side(pump inlet line)
Old 03-20-2014, 03:57 PM
Zoomin0074 Zoomin0074 is offline
Vehicle: None
Zoomin0074 is on a distinguished road
i just recently had the same type of situation.. Mine was the rack and pinion seal on drivers side all the fluid leaked into the boot which held it in except for a slight drip here and there.. I could not figure out where all the fluid went, replaced rack and all is good.
Old 04-18-2014, 10:54 AM
wpattie wpattie is offline
Vehicle: 2004 Dodge Ram 1500
Rep:72
wpattie will become famous soon enough
I have the same problem, at idle no p/s. Then I bring the RPM up to about 1000 and good to go. It started doing this as soon as I changed my S-belt. Should I change the pump or is there any chance it could just be the pulley?
Old 04-18-2014, 11:06 AM
tonw07's Avatar
tonw07 tonw07 is offline
Vehicle: 2008 Dodge Ram 1500
Rep:42
tonw07 is on a distinguished road
I also had a similar issue. I had a pump installed, went out a couple months later and then left me stranded. Had another pump installed and the shop noticed it was getting hot and that there wasn't a very good flow with the fluid so they checked it again and there was some obstructions coming from the rack so i had to replace the entire rack. Wasn't a cheap fix, but 2 months later everything is working like it should.
Good luck and let us know what you figure out!
RIP :'(
power steering
