Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Detailing and General Maintenance Forum > Drive Line
Drive Line Ball Joints - Wheel Bearings - Shocks - Springs - Alignment etc.
Old 04-21-2011, 12:46 PM
Elsanto Elsanto is offline
Vehicle: 2008 Dodge Ram 1500 5.7L
Trim Level: 22
Elsanto is on a distinguished road
Default 08 dodge ram 1500 2wd lift
Recently I lift the front 1.5 inch the technician said that I need to repalce the front shock to another with an inch more of travel, actully my shock meassure 17 inch extended now need a 18 or 19 inch extended, 2 question do i need this... where can i find this shock I look every where in the net.
Old 04-24-2011, 11:56 AM
williamhartle's Avatar
williamhartle williamhartle is offline
Vehicle: 2007 dodge ram
Trim Level: st
williamhartle is on a distinguished road
yes u need it i have a 2inch lift and didnt change them needless to say there toast. same thing happened on my dads 2010 2500 6.7, he didnt change the shock and they also are done. the problem is that your stock shock is going to be constantly being over extended and it prematurely fails. you could also get something i believe is called as shock extender but im not sure. basically itsa bracket that mounts to the top of your shock and to the point where it mounts giving you a new lower mounting point.
2 inch leveling lift 3 inch body lift, 34" bfg mud terrain TA KM2, straight pipe, vararam intake, superchips cortex, Firestone air bags, skyjacker n8000 shocks rear, s8000 front struts, painted head lights, tinted tail,cab mount light, big shiny chrome balls.
Old 11-27-2011, 02:58 AM
clewis33's Avatar
clewis33 clewis33 is offline
Vehicle: 2008 Ram 1500 5.7L Hemi 2WD
Color: Grey
clewis33 is on a distinguished road
Default Need help
Hey I have a question for everyone. I have a 2008 1500 2wd 5.7L. I got 3" Lift Spindles, 1.5" daystar coil spacers, Bilstein front shocks that are 2" longer than stock. I have 17x9 MT wheels with 4.5" backspacing -12 offset and 315/70/17 Goodyear Duratracs which come to about 34.5" Tires. Do you think I should have enough room or will I run into any issues? Not really trying to add a body lift but maybe a 3" PA Body Lift would help with everything too even though I'm trying to stay away from that. Also thought about maybe gettin 2" Rear Lift Shackles also? Any help would be great. Thanks
Old 01-29-2012, 05:22 PM
coastie coastie is offline
Vehicle: 2008 Dodge Ram 1500 ST
Trim Level: 1500 ST
coastie is on a distinguished road
Yes, you will need a little more lift to fit those tires. I have 33x12.5x17s on my truck with a 4" spindle lift, 1" rear blocks, and Rancho 9000s front and rear. I check the flex this weekend and the rear tire fit perfectly into the wheel well. Any larger and I would have had a good amount of rub. Same up front. I have pic's also if you would like to see how they fit in the well.
Old 10-29-2012, 09:30 PM
Kustomblack1's Avatar
Kustomblack1 Kustomblack1 is offline
Vehicle: 2008 dodge ram
Trim Level: 1500
Color: Pearl electric blue
Kustomblack1 is on a distinguished road
Default What's up guys?
lets just truck!
Old 10-29-2012, 09:32 PM
Trim Level: 1500
Default This might not help, sorry
lets just truck!
lifted dodge ram 1500 price? opnions?? usmcoorah Dodge Ram General Discussion 4 10-08-2011 11:04 AM
07 dodge ram 1500, improving stock suspension. booyah Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 1 03-14-2011 03:04 AM
Truxxx Lift and Level Kit for your 2007 Dodge Ram 1500 QuadCab 2wd DanoHB Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 13 07-11-2010 01:31 PM
2007 Dodge ram 1500 5.7 Hemi proc omp stage 1 lift Glowworm23 Newbie Checkin! 12 06-08-2010 03:06 PM
2010 Ram 1500 4X4 Lift Help! Cap10crch 2010 Dodge Ram Forum 6 03-02-2010 12:28 PM
