Old 05-04-2011, 04:01 PM
dustin72's Avatar
dustin72 dustin72 is offline
Vehicle: 2013 Dodge Ram1500 4x4
Rep:48
dustin72 is on a distinguished road
Originally Posted by Crash View Post
So you run superchips and it allows you to lower torque management?
Yes, IF you purchase the Advanced Trans Options for $40.
Black SRT10 22's with 305/45/22 Nitto NT420S Tires, 6000k Low and Fog HID's, Debadged, Tint, Custom Mopar Badges, S&B Intake, Magnaflow Muffler, Superchips Tuner
Old 05-04-2011, 08:40 PM
Crash's Avatar
Crash Crash is offline
Color: Deep water blue
Rep:401
Thanks for the info Dustin, I have been doing some reading on S/C web site. So what do you run your TM set at?
Old 05-05-2011, 11:27 PM
dustin72's Avatar
Rep:48
I started with 8% and now I'm at 6%. Shifts good, don't think I'd go any lower than 6%.
Old 05-13-2012, 08:41 AM
MF2000's Avatar
MF2000 MF2000 is offline
Vehicle: 2009 Ram Crew Cab
Color: Inferno Red
Rep:13
MF2000 is on a distinguished road
Originally Posted by dustin72 View Post
I tried 6000rpm WOT shift points today. Dropped 2 tenths from the 5500rpm setting and also picked up 1-2 MPH. Runs were more consistent as well. 6200rpm setting is next.
What were the OEM shift points?
Just so I understand this......when you adjusted from OEM to 5500 rpm, your time was slower by a tenth?
When you switched from 5500 rpm to 6000....you went faster by 2 tenths....is that correct?
Old 05-15-2012, 06:12 PM
MF2000's Avatar
Color: Inferno Red
Rep:13
Bueler? Bueler? Bueler?
Old 05-15-2012, 10:03 PM
mangoram10's Avatar
mangoram10 mangoram10 is offline
Vehicle: 2010 Ram
Color: Mango Tango pearl
mangoram10 is on a distinguished road
My 1-2 2-3 shifts are set at 6200 with my trinity and I couldnt be happier.
2010 CC 4x4 w/3.92s-5810lbs, diablo 93 tune, 14.41@96...330rwhp/347rwtq
Old 05-16-2012, 06:41 PM
MF2000's Avatar
Color: Inferno Red
Rep:13
Stock valve springs?
Old 05-20-2012, 09:45 PM
MF2000's Avatar
Color: Inferno Red
Rep:13
What is the highest we should rev with a stock valvetrain?
Old 05-21-2012, 07:32 PM
RTBenny RTBenny is offline
Vehicle: 2012 Ram R/T
RTBenny is on a distinguished road
I've heard the first limit on the Hemis isn't the valvetrain but instead the harmonic balancer on the crank. It's been known to fail as low as 6400 rpm I've heard. That's why my rev limit will be set at 6300 when (if) they ever release a tuner.
Also, as far as setting shift points, to make a fairly accurate guess, some math would have to be done for each gear change, as well as knowing your peak horsepower. Each gear change may need to be made at different points in order to keep you nearest the peaks for the longest amount of time. Also, forget torque peak when drag racing. Hp peak is where you want to stay. And before anyone yells foul, remember HP is just torque relative to rpm.
In my case, my power peaked around 55-5600. This means the perfect shift from first to second would be around 62-6300. But wait, that's only assuming that the power drops off after peak at the same rate it rises to peak. That's probably not the case and if I had to guess, these trucks would probably do great shifting at 6500. I won't do it, but you guys feel free.
2013 F-150 King Ranch 4wd 5.0
Old 05-21-2012, 08:51 PM
MF2000's Avatar
Color: Inferno Red
Rep:13
Thank you for the info on the harmonic balancer. This is the first I've heard of that issue.
Above you mentioned your power peaked at 5500-5600, making your perfect shift point 6200-6300. How did you come to this conclusion?
I'm not disputing you, just trying to understand how you figured that was the optimal shift point.
Hemi Hat Sneak Peak Crash Custom Dodge Ram Interior and Exterior Lighting 54 07-26-2012 05:33 PM
Sneak Peak Mufflex Tips JEC Exhaust 16 01-28-2011 09:28 PM
Sneak peak from the dealer Indeepcamo 2010 Dodge Ram Forum 9 04-08-2010 08:19 AM
Header Question ScatPak07 Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 31 03-17-2010 07:24 PM
