Old 05-22-2012, 09:46 AM
RTBenny RTBenny is offline
Vehicle: 2012 Ram R/T
RTBenny is on a distinguished road
Originally Posted by MF2000 View Post
Thank you for the info on the harmonic balancer. This is the first I've heard of that issue.
Above you mentioned your power peaked at 5500-5600, making your perfect shift point 6200-6300. How did you come to this conclusion?
I'm not disputing you, just trying to understand how you figured that was the optimal shift point.
No problem. First, I only figured out the first gear to second gear change. It could be different for 2nd to 3rd or 3rd to 4th. First gear is a 3:1 ratio and second is a 1.67:1 ratio so whenever it shifts from first, your tach is going to drop 2800 rpm. Unfortunately, my engine is only at peak horsepower for 100 or so rpm, so maintaining peak power is impossible. The next best thing is to stay as close to peak as often as possible. So you basically just split the rpm difference of the two gears (2800 rpm) on either side of the power peak. 1400 above peak would put my engine at 6900 rpm which ain't gonna happen. So, the best bet is to go as high as possible, which since that balancer is limited to 6400, 6200-6300 becomes our best possible shift point. And Chefred can shed more light on that balancer problem. He's the one that posted it I believe.
2013 F-150 King Ranch 4wd 5.0
Old 05-22-2012, 04:31 PM
MF2000's Avatar
MF2000 MF2000 is offline
Vehicle: 2009 Ram Crew Cab
Color: Inferno Red
Rep:13
MF2000 is on a distinguished road
Is that why he went with the underdriven one from Summit?
Old 06-23-2012, 07:02 AM
KarateManAZ's Avatar
KarateManAZ KarateManAZ is offline
Vehicle: 2009 Dodge Ram
Trim Level: MagnaHEMI
Color: Deep Water Pearl Blue
Rep:120
KarateManAZ will become famous soon enoughKarateManAZ will become famous soon enough
2009 Ram 1500 Crew Cab - Deep Water Pearl Blue
2/4 Drop, 0212353 Retro Shop Projector Retrofit w/ custom paint, Jet 180 T-Stat, AR LT Headers, 545rfe w/ deep pan,
Inertia Cam, Edge Triple Disk, Magnaflow 18"
Oh Yeah its a MagnaHEMI 12.2@109
Old 06-23-2012, 07:38 AM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2009 Ram Crew 2WD
Trim Level: Lone Star
Rep:252
Nice numbers & flat curves but why did they chart your dyno run in SAE and not STD?
Old 06-23-2012, 08:48 AM
Rep:120
not sure on the difference?
Old 06-23-2012, 09:30 AM
CHVYKLR's Avatar
Rep:252
Guess that's what i get for posting before fully awake. SAE is what you want to see and is believed to be a closer representation to real world hp #s. STD #s would be higher. Sorry for my last post. Those are great numbers! How many psi did you peak at? Cant wait to see it with the stroker.
Old 06-23-2012, 09:37 AM
Rep:120
Psi peaked at 9. Stroker goes in today and will get it running. A few months down the road I will be going to 15psi.
Old 06-23-2012, 10:56 AM
CHVYKLR's Avatar
Rep:252
That thing will be a beast.
Old 06-23-2012, 01:32 PM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
I can't wait to see that bad boy in person...a few of the norcal guys are gonna roadtrip an visit Chris an Mikee sometime in the future...i wanna get more details on your 370 build, you're makin me think about this now... the only reference i think I made regarding the balancer is that the one I got won't work on the 4th gens..hehe, I was gonna ask you regarding the balancer limit myself... i only did this because i ran out of mods to do and this was logical since it was sfi rated...
Old 06-27-2012, 07:33 AM
Rep:120
That would be cool if you guys made a trip out! It might be a little warm right now though
Hemi Hat Sneak Peak Crash Custom Dodge Ram Interior and Exterior Lighting 54 07-26-2012 05:33 PM
Sneak Peak Mufflex Tips JEC Exhaust 16 01-28-2011 09:28 PM
Sneak peak from the dealer Indeepcamo 2010 Dodge Ram Forum 9 04-08-2010 08:19 AM
Header Question ScatPak07 Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 31 03-17-2010 07:24 PM
