Old 04-21-2011, 09:59 PM
limitlessent's Avatar
limitlessent limitlessent is offline
Vehicle: 2013 Dodge Ram 2500 4WD
Rep:13
limitlessent is on a distinguished road
Send a message via AIM to limitlessent
Default Predator question... 87 tune on 87 fuel vs 91 tune (modded) to run on 89 fuel
Ok... On my DSP....
Is there any advantage to one of these over the other:
1.) Running 87 tune on 87 octane
2.) Running 91 tune on 89 octane but modifying the 91 tune to be proper for 89 octane fuel?
If #2 is the best choice, what changes would be necessary to make it happen?
Also, how do I properly log to see if I'm getting knock etc? What #'s are in a good range and what pids do I log?
Thanks guys!!
Old 04-21-2011, 10:20 PM
dustin72's Avatar
dustin72 dustin72 is offline
Vehicle: 2013 Dodge Ram1500 4x4
Rep:48
dustin72 is on a distinguished road
I have basically the same question. I'm trying the Superchips 93 octane tune on 91 octane fuel. But since I'm at 2200ft, I thought that I may be able to get away with it without running into excessive KR. How much is excessive KR? I was seeing a peak of about 3* for about a second or two under the most extreme loading. Under 98% of driving under various loads and rpms, KR was basically non-existent.
Black SRT10 22's with 305/45/22 Nitto NT420S Tires, 6000k Low and Fog HID's, Debadged, Tint, Custom Mopar Badges, S&B Intake, Magnaflow Muffler, Superchips Tuner
Old 04-21-2011, 10:32 PM
mbehlok's Avatar
mbehlok mbehlok is offline
Vehicle: 2014 Dodge Ram Laramie 4X4
Trim Level: laramie
Rep:39
mbehlok is on a distinguished road
You can prolly check with Johan over at Diablo.. I have been running the 93 tune with 93 octane gas for a few tanks and the truck seems to be getting better and better as the computer adjusts to the new parameters.
I figure its only a couple bucks to fill up with 93 octane as opposed to 89 or 91 octane. You just have to make sure that you can get that octane where you are.
Johan just sent me a custom tune that helped with the tranny shifts and now its even better than it ever was.
Check this link, Johan has some recommended PIDs to log, you can also download the DCX file and put it in the right directory on your laptop so that its already setup for the PIDs..
http://www.diablosport.com/index.php...wtopic&t=21253
Hope that helps..
Stock for now!
Old 04-21-2011, 10:36 PM
Rep:13
Thanks.. I've emailed diablosport... I'll post the answer here if someone doesn't answer it before I hear from them.
Old 04-22-2011, 10:51 AM
Rep:13
Ok.. Mike @ Diablosport answered this:
Not the best idea, Id do the 89 with the 87 tune if anything.
Old 04-22-2011, 10:52 AM
Rep:13
I guess I'm just gonna run the 87 tune on 89 gas.
Right now I'm running 87 tune on 87 gas but don't know how to check to see if it's a problem or not...
Old 04-22-2011, 08:35 PM
nate8604's Avatar
nate8604 nate8604 is offline
Vehicle: 2008 Dodge Ram 1500
Trim Level: SLT/Big Horn
Rep:36
nate8604 is on a distinguished road
Thats what I started out with running the 87 tune on 89. The past three fill-ups I switched to the 93 octain tune and have been filling up with 93 and with each tank the truck's performance continues to improve (including mpg's).
Old 04-23-2011, 12:09 AM
Rep:13
I was about out of gas anyway (under 1/8th tank). I filled up with 89 octane.. drove about 75 miles and re-checked the readings... numbers look the same.
I reset to factory defaults and checked again. Now my ST ratings max was only 4.0 but only VERY briefly when MDS kicks in and out.
LT was 0 the whole time... WOT, cruising, MDS in and out... stayed at 0.
So.. what do I need to do to get the 87 tune to not show high KNK #'s?
Thanks...
error code list moparmike07 Dodge Ram Knowledge Base 16 02-15-2014 04:16 PM
Fuel Fill Nozzle Shuts Off RamTech Dodge Ram Knowledge Base 3 11-22-2013 09:22 PM
SS/T Problems round 2 98sst Custom Dodge Ram Performance Mods - Engine - 5.9 Liter V8 48 01-11-2010 07:54 PM
Fuel fill problems RamTech Dodge Ram Knowledge Base 3 01-09-2010 10:38 AM
dtc po148 nachizzle Cummins Diesel Specific Topics 2 06-09-2009 12:36 PM
